Set up a connection to Backcountry
    –or–
    –or–
Select Backcountry AS2 or Backcountry FTP in the EDI trading partners list.
Supported Backcountry X12 document types
The supported X12 document types for the Backcountry trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase Order
