–or–
–or–
Select Cardinal Distributing AS2 or Cardinal Distributing FTP in the EDI trading partners list.
The supported X12 document types for the Cardinal Distributing trading partner are listed below:
810 - Invoice
844 - Product transfer account adjustment
849 - Response to product transfer account adjustment
850 - Purchase order
855 - Purchase order acknowledgement
