Set up a connection to CVS
    –or–
    –or–
Select CVS AS2 or CVS FTP in the EDI trading partners list.
Supported CVS X12 document types
The supported X12 document types for the Big Lots trading partner are listed below:
  • 810 - Invoice
  • 812 - Credit/Debit Adjustment
  • 816 - Organizational Relationships
  • 820 - Payment Order/Remittance Advice
  • 824 - Application Advice
  • 830 - Planning Schedule with Release Capability
  • 832 - Price/Sales Catalog
  • 846 - Inventory Inquiry/Advice
  • 850 - Purchase Order
  • 852 - Product Activity Data
  • 855 - Purchase Order Acknowledgment
  • 856 - Advance Ship Notice (ASN)
  • 860 - Purchase Order Change Request - Buyer Initiated
  • 864 - Text message
