Set up a connection to HD Supply
    –or–
    –or–
Select HD Supply AS2 or HD Supply FTP in the EDI trading partners list.
Supported HD Supply X12 document types
The supported X12 document types for the HD Supply trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase Order
  • 864 - Text Message
