Set up a connection to 84 Lumber
    –or–
    –or–
Select 84 Lumber AS2 or 84 Lumber FTP in the EDI trading partners list.
Supported 84 Lumber X12 document types
The supported X12 document types for the 84 Lumber trading partner are listed below:
  • 810 - Invoice
  • 820 - Payment order/Remittance advice
  • 850 - Purchase order
  • 870 - Order status report
