Set up a connection to Bank of America
    –or–
    –or–
Select Bank of America AS2 or Bank of America FTP in the EDI trading partners list.
Supported Bank of America X12 document types
The supported X12 document types for the Bank of America trading partner are listed below:
  • 820 - Payment Order/Remittance Advice
