Set up a connection to KeHe
    –or–
    –or–
Select KeHe AS2 or KeHe FTP in the EDI trading partners list.
Supported KeHe X12 document types
The supported X12 document types for the KeHe trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase Order
  • 855 - Purchase Order Acknowledgment
