Set up a connection to Associated Food Stores
    –or–
    –or–
Select Associated Food Stores AS2 or Associated Food Stores FTP in the EDI trading partners list.
Supported Associated Food Stores X12 document types
The supported X12 document types for the Associated Food Stores trading partner are listed below:
  • 875 - Grocery Products Purchase Order
  • 880 - Grocery Products Invoice
