Set up a connection to Big 5 Sporting Goods
    –or–
    –or–
Select Big 5 Sporting Goods AS2 or Big 5 Sporting Goods FTP in the EDI trading partners list.
Supported Big 5 Sporting Goods X12 document types
The supported X12 document types for the Big 5 Sporting Goods trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase Order
  • 855 - Purchase Order Acknowledgment
  • 856 - Advance Ship Notice (ASN)
  • 860 - Purchase Order Change Request - Buyer Initiated
