NetSuite saved search for syncing inventory: Select appropriate saved search. Refresh to fetch the latest values for the saved search.
NetSuite saved search for syncing inventory for Kit Items: Select appropriate saved search. Refresh to fetch the latest values for the saved search.
Calculate Kit Inventory per Location: If enabled, the Integration App will first calculate a sellable inventory of kit per location using the quantity of each member item, and then will send the sum of all the sellable quantities across all the locations. If disabled, the Integration App will first calculate the total inventory for each member items across all the locations, and then will calculate sellable inventory for a kit.
Always sync inventory levels for entire catalog: Syncs inventory for all the NetSuite items linked to eBay, every time inventory export data flow runs.
NetSuite locations to pick inventory from: Inventory export data flow picks the inventory (for all the NetSuite items linked to eBay) from the chosen NetSuite locations and syncs/exports it to eBay. If multiple locations are selected, the inventory from all these locations is added to the total and synced to eBay.
