Manage Walmart sales tax for states with Marketplace tax facilitator
6 comments
  • David Eisen
    I tried adding these handlebars but am getting an error when running the flow that the expression is incorrect.
    0
  • KHAISAR AHMAD QA Lead
    Celigo University Level 4: Legendary
    Answer Pro
    Great Answer
    Hello David Eisen
    Can we please get more details on the issue. What is the tax setup you are using? Are you using Line level Taxes or Body Level Taxes? Can you also please provide the error you are getting in the flow run.
    0
  • David Eisen
    Sure,
    We're using body level taxes, here's the error:
    "Failed to add Walmart Order# 2815784269456. Could not compile handle bar \"{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'AK'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'DE'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'FL'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' ‘KS'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'LA'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'MS'}}{{#compare (u...
    0
  • David Eisen
    Hi Khaisar,
    Have you had a chance to look into this error?
    0
    Answer Pro
    Great Answer
    Hello David Eisen
    Sorry for the delay. Yes, I tried debugging this further and able to find the issue. If you observe the below screenshot, for the state code KS, it is opened with an incorrect symbol. It has to be a single quote. I have pasted the updated handlebar below for both the mentioned mappings,
    For "istaxable" field mapping
    {{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'AK'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'DE'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'FL'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'KS'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'LA'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'MS'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'MO'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'MT'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'NH'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'OR'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'TN'}}F{{else}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}
    For "taxrate" mapping
    {{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'AK'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'DE'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'FL'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'KS'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'LA'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'MS'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'MO'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'MT'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'NH'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'OR'}}{{#compare (uppercase shippingInfo.postalAddress.state) '!==' 'TN'}}0{{else}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}{{/compare}}
    Please review this and let us know if you are still facing the issue.
    0
  • David Eisen
    Your fix is working well,
    Thank you!
    0
