Skip to main content
Asynchronous exports and imports using async helpers
1 comment
  • Martin Jahn Channel Partner
    Engaged
    Celigo University Level 1: Skilled
    Tom Santiago Santiago My Transformation step is not being executed when applied to an Export that is using the Async Helper. I also added a PreSavePage script with a debug line to log the options.data value and this does not seem to be getting triggered either.
    Is there any know limitations when using the Async Helper on an export (HTTP connector)?
    There is very few support articles on the Asnc Helper so any knowledge you can share will be helpful.
    0
