Note: We’ve renamed our SmartConnectors to Integration Apps.
Required configuration needed to establish the NetSuite connectionEnable SuiteTalk (Web Services) and SuiteScript
To enable SuiteTalk (Web Services) and SuiteScript in NetSuite, go to Setup > Company > Enable Features. Select SuiteCloud in the sub-menu. The features are displayed. Select the SuiteScript and SuiteTalk (Web Services) checkbox and click Save.
NetSuite information needed to establish NetSuite connection with Integration App
Celigo’s iPaaS platform integrator.io Integration App requires the following information from NetSuite to be entered when configuring NetSuite connection:
- Account ID
- Role ID
- Password
The Role ID is the NetSuite Internal ID of the Role associated with the Account ID (User). To obtain this value you must first know the Account ID associated with the user you are using for this connection. One way to obtain this value within NetSuite is via Setup > Integration > Web Services Preferences > Account ID.
Once you know the Account ID, you can navigate to Setup > Users/Roles > Manage Roles > Internal ID and if you have NetSuite Internal Ids displayed automatically it will just show in the list view, or you can open the Role in view mode and look at the URL in the browser and the ID will be listed there too.
Note: To enable the visibility of internal IDs in NetSuite, go to Home > Set Preferences > General Tab > Set Defaults and select the Show Internal IDs checkbox.
Ways to establish NetSuite Connection with integrator.io
You can establish your NetSuite account connection with integrator.io in the following ways:
- Setup the NetSuite connection with administrator access.
You can choose to assign the Account ID (user) you provide when installing a Celigo’s Integration App with the administrator role in the Role ID field. Default internal id for an administrator role in NetSuite is “3”. - Setup the NetSuite connection without administrator access.
If you do not want to associate the administrator role with the Account ID you provide when installing a Celigo’s Integration App, you will need to ensure that the Role ID associated with the Account ID has the necessary permissions for the Integration App to access the required details from your NetSuite account. The following section provides more details on permission needed to establish NetSuite connection with a non-administrator role.
Recommendation: When you use the same login for multiple Celigo Integration Apps, the concurrency of that login is shared by all the connections. As NetSuite allows you to make only 10 concurrent RESTlet requests at a time per login, we recommend you to use separate NetSuite user login (email and password) for each Integration App for better throughputs.
Set up permissions for non-administrators roles in NetSuite
Each non-administrator will be able to only access the NetSuite record types that their role permits. Not having adequate role permissions could lead to unwanted errors when executing the data flows. In order for the user to set up, run, and maintain integrations in Celigo integrator.io platform with a non-administrator role, you need to provide controlled access using the Permissions option in NetSuite.
To set up controlled access permissions in NetSuite, select Setup > Users/Roles > Manage Roles. The Manage Roles page is displayed. Find the role for which you need to customize the permissions and click Customize. The Role page is displayed.
In the Permissions tab, ensure that the following permissions are enabled for the user:
Section | Permission | Level |
Transactions | ||
Transactions | Cash Sale | Full |
Transactions | Cash Sale Refund | Full |
Transactions | Credit Memo | Full |
Transactions | Customer Deposit | Full |
Transactions | Customer Payment | Full |
Transactions | Customer Refund | Full |
Transactions | Deposit | Full |
Transactions | Find Transaction | Full |
Transactions | Fulfill Orders | Full |
Transactions | Invoice | Full |
Transactions | Item Fulfillment | Full |
Transactions | Item Receipt | Full |
Transactions | Receive Returns | Full |
Transactions | Refund Returns | Full |
Transactions | Return Auth. Approval | Full |
Transactions | Return Authorization | Full |
Transactions | Sales Order | Full |
Transactions | Sales Order Approval | Full |
Lists | ||
Lists | Accounts | Full |
Lists | Bins | Full |
Lists | Contacts | Full |
Lists | Currency | Full |
Lists | Custom Record Entries | Full |
Lists | Customers | Full |
Lists | Departments | Full |
Lists | Documents and Files | Full |
Lists | Items | Full |
Lists | Locations | Full |
Lists | Mass Updates | Full |
Lists | Notes Tab | View |
Lists | Payment Methods | Full |
Lists | Perform Search | Full |
Lists | Publish Search | Full |
Lists | Record Custom Field | Full |
Lists | Shipping Items | Full |
Lists | Subsidiaries | Full |
Lists | Tax Items | Full |
Setup | ||
Setup | Accounting Lists | View |
Setup | Allow JS/HTML Uploads | Full |
Setup | Custom Address Form | View |
Setup | Custom Body Fields | View |
Setup | Custom Column Fields | View |
Setup | Custom Entity Fields | View |
Setup | Custom Fields | View |
Setup | Custom Item Fields | Full |
Setup | Custom Lists | Full |
Setup | Custom Record Types | Full |
Setup | Custom Sublists | View |
Setup | Custom Transaction Fields | Full |
Setup | Custom Transaction Forms | View |
Setup | Customer Status | Full |
Setup | Deleted Records | Full |
Setup | Import CSV file | Full |
Setup | Manage Users | Full |
Setup | Other Custom Fields | View |
Setup | Other Lists | View |
Setup | SuiteBundler Audit Trail | Full |
Setup | SuiteScript | Full |
Setup | SuiteScript Scheduling | Full |
Setup | Update Prices | Full |
Setup | View Login Audit Trail | Full |
Setup | Web Services | Full |
Setup | Workflow | Full |
Amazon Seller Central Verification Process
Because of Amazon's verification process, you will need to create an account in the seller central that points to a distribution list within your organization.
Suggested recipients would be your organization's Amazon contact and amz_verification@celigo.com so that the Celigo implementation team can request Verification codes, enabling them to access your Amazon Seller Central account.
If a distribution list is not achievable with your email platform, please create a forwarding rule in your email account that will email the Celigo verification email address anytime a verification code is requested.
