Set up a basic auth connection to Anaplan
Anaplan is a market-leading, cloud-native company transforming industries to see, plan, and drive business performance.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings.
Setting Instructions
Name your connection * Enter a clear and distinguishable name. (Throughout integrator.io imports and exports, you will have the option to choose this new connection.) A unique identifier will prove helpful later when selecting it from a list of the connections that you’ve created.
Auth type * Select Basic as the authentication type for this connection (the token option is described separately).
Username * Enter your Anaplan account username.
Password * Enter your Anaplan account password.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
Tips:
  • This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic auth universal connector documentation.
  • Use an FTP connector to upload files to Anaplan. If you are sending BLOB files from NetSuite to Anaplan, you can customize your flows based on the NetSuite to FTP template.
Additional references
