Set up a connection to OANDA Exchange Rates
OANDA Currency Converter allows you to check the latest foreign exchange average bid/ask rates and convert all major world currencies.
Setting
Instructions
Name your connection *
API key *
Enter your OANDA Exchange Rates account API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API key
  1. Sign in to your OANDA customer self-service portal.
  2. Navigate to My subscriptions.
  3. Copy the API key.
The API key will also be sent to your email account after you create the OANDA Exchange Rates account.
