Note: Slack has announced that the creation of legacy test tokens is deprecated, and new tokens will not be issued after May 5, 2020. Switch to integrator.io beta for a Slack connection with OAuth 2.0 support.
Slack links: API guide, Authentication
- Name: Required: Name your connection.
- Connection type: Required: The form will automatically choose Slack.
- Token: Required: Enter the token. Use the following steps to create the token:
- Borrow concurrency from (optional): Select another connection from the list....
- Concurrency level (optional): Up to 25 allowed....
Read more about this connection:
