ServiceNow is a cloud computing platform that helps companies to manage digital workflows for enterprise operations.
ServiceNow documentation: API guide, Authentication
Contents
- A. Set up a ServiceNow connection
- B. Provide required ServiceNow application details
- C. Edit advanced ServiceNow settings
- D. Test the connection
Start establishing a connection to ServiceNow in either of the following ways:
In the resulting Application list, select ServiceNow.
The Create connection panel opens with required and advanced settings.
At this point, you’re presented with options for providing ServiceNow authentication.
Authentication type (required): Select Basic (the OAuth 2.0 option is described separately).
Subdomain (required): Enter your ServiceNow subdomain. To find your subdomain, log in to your ServiceNow account. For example, if https://test89098.service-now.com
is the URL, then test89098
is your subdomain.
Username (required): Enter the username of your ServiceNow account.
Password (required): Enter the password of your ServiceNow account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the ServiceNow connection.
Once you have configured the ServiceNow connection, you have a few options for continuing:
- Save & close – click to test and save the connection and exit the Create connection panel
- Close – click to exit without saving any new changes
