Acumatica is a complete cloud ERP platform that provides solutions for all your business management needs.
Acumatica documentation: Developer guides
Contents
- A. Set up an Acumatica connection
- B. Describe the Acumatica connection
- C. Provide required Acumatica account information
- D. Edit advanced Acumatica settings
- E. Test the connection
- Troubleshoot Acumatica API login limit error
Start establishing a connection to Acumatica in either of the following ways:
In the resulting Application list, select Acumatica.
The Create connection panel opens with the required and advanced settings.
- Cloud to connect to a publicly accessible server application
- On-premise to connect to a server that is publicly inaccessible and has integrator.io agent installed on it
At this point, you’re presented with a series of options for providing Acumatica authentication.
Authentication type (required): Select Cookie (the OAuth 2.0 option is described separately).
Instance URI (required): Enter the instance URI shown in your Acumatica account URL. For example. http://try.acumatica.com/isv/entity/Default/6.00.001
Endpoint name (required): Enter the endpoint name found in your Acumatica account under Web service endpoints. Currently, we are supporting the Default, Manufacturing, and Ecommerce as endpoint names.
Endpoint version (required): Enter the endpoint version found in your Acumatica account under Web service endpoints. This setting defaults to the current version.
Username (required): Enter the username for your Acumatica account.
Password (required): Enter the password for your Acumatica account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
Company (optional): Enter the company name for your Acumatica account.
- Sign in to your Acumatica account
- Search for Web service endpoints. The search result displays the API in the Endpoints folder.
Notice that it also displays the endpoint name and version, required for your connection:
If your instance of Acumatica is stored on a local server (on-premise), you can establish your connection with the following steps:
- Install and activate an on-premise agent.
- Enter the localhost URL in the Instance URI field.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Acumatica connection.
Once you have configured the Acumatica connection, you have a few options for continuing:
- Save & close – click to test and save the connection and exit the Create connection panel
When saving or testing the connection, integrator.io sends a call to Acumatica’s authentication URI. If you then click Save & close, the second call might cause the API login limit error since some Acumatica licenses support only one call at a time. To avoid this error, do not click Test connection during setup.
The API login limit is tied to the license. Trial mode allows only two concurrent users and one API user to simultaneously use the system. If the customer is using a trial mode Acumatica account, the connection may trigger an API login limit error. If you receive this error, wait 10 minutes before attempting the connection.
For more information, see the Acumatica licensing restrictions.
