Jira documentation: API guide, Authentication
1. Set up a Jira Cloud platform connection
Start establishing a connection to Jira Cloud platform in either of the following ways:
In the resulting Application list, click Jira Cloud platform.
2. Edit required Jira Cloud platform settings
At this point, you’re presented with a series of options for modifying the Jira Cloud platform authentication.
- Name (required): Name the connection.
- Base URI: The base URI for Jira Cloud platform is https://<your-domain>.atlassian.net. Replace <your-domain> with the base URL for your Jira Cloud platform.
- Username (required): The username of your Jira Cloud platform account.
- API Token (required): API token for the Atlassian account. To generate a token, log in to your Atlassian account, and go to Atlassian account settings > Security > API token > Create and manage API tokens.
- Borrow concurrency from (optional): Select another connection from the list
- Concurrency level (optional): Up to 25 allowed
3. Test and save the connection
Once you have configured the Easyship connection, you have a few options for continuing:
