Magento is an open-source eCommerce platform with features like order management, business intelligence, and shipping.
Magento 2 documentation: API guide, Authentication
Contents
- A. Set up a Magento 2 connection
- B. Provide required Magento 2 application details
- C. Edit advanced Magento 2 settings
- D. Test the connection
Start establishing a connection to Magento 2 in either of the following ways:
In the resulting Application list, select Magento 2.
The Create connection panel opens with required and advanced settings.
At this point, you’re presented with options for providing Magento 2 authentication.
- Cloud to connect to a publicly accessible server application
- On-premise to connect to a server that is publicly inaccessible and has integrator.io agent installed on it
Base URI (required): Enter the base URI of your Magento 2 account. You can locate this URL in the address bar after you sign in to your Magento 2 account. For example, if your account is located at http://123.12.12.1/xyz/admin
, then replace admin
with rest
and enter the base URI as http://123.12.12.1/xyz/rest
Username (required): Enter the username of your Magento 2 account.
Password (required): Enter the password of your Magento 2 account. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Generate token (required): Click Generate token to have integrator.io fill in an encrypted access token or enter the token generated for you by Magento 2. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must generate this value again; it is stored only when the connection is saved and never displayed as text.
- Errors while retrieving the token are often attributed to an incorrect base URI being used or your incorrect credentials. It's best to enter them in by hand and ensure that the browser autofill function doesn't override your activity.
- For Magento accounts updated to 2.4.4 and above versions, the integration tokens can no longer be used for API bearer token authentication. To revert to the previous behavior, you should either disable two-factor authentication or run the bin/magento config:set oauth/consumer/enable_integration_as_bearer 1 command to restrict the new behavior. For more information, see Token-based authentication.
- For Magento accounts using two-factor authentication, you have to enter the token in the Token field.
- For Magento accounts using two-factor authentication, when you upgrade to a higher version, integrator.io doesn't get the connection up and running. This is because Magento is expecting a new token for a successful connection with integrator.io. To resolve this, create a token outside of integrator.io, enter the token when logging into Magento, and then enter the same token in the Token field. For more information on how to generate a token, see Token-based authentication.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Magento 2 connection.
Once you have configured the Magento 2 connection, you have a few options for continuing:
- Save & close – click to test and save the connection and exit the Create connection panel
- Close – click to exit without saving any new changes
2 comments
Generate token is not working
I am confused about the generate token step. What should I do if I do not use 2FA on Magento.
In integrator.io it says
"Click the Generate token button to have integrator.io fill in an encrypted access token or enter the token generated for you by Magento 2."
I am under the impression that if I dont use 2FA the generate token would generate one it self. But when I click it, the token entry shows an error, requesting a value to be entered then it just says generating... but nothing is generated and after clicking generate a couple of time, you start getting this error
So its either I must have 2FA or the generate token does not work.
Another issues is I can type in random/incorrect login credential, random/incorrect token value and still get a successful connection message, this is counterintuitive and brings into question, is proper verification being done?
