PowerBI documentation: API guide, Authentication
A. Set up a PowerBI connection
Start establishing a PowerBI connection in either of the following ways:
In the resulting Application list, select PowerBI.
B. Provide PowerBI application details
Admin user: Check this box if you are the PowerBI service administrator. This role can be assigned to users who need access to the PowerBI Admin Portal without also granting them other Office 365 administrative privileges.
C. Edit advanced PagerDuty Events settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the PagerDuty Events connection.
D. Test the connection
- Click Save & authorize. The following page displays:
- Enter your registered email address.
- Enter the password of your registered PowerBI account.
- Click Accept to create the connection.
1 comment
So after the integration between power bi and another data source, will celigo provide some sort of an online database power bi desktop can connect to? I dont see any celigo connector in power bi desktop.
