LiquidPlanner documentation: API Guide, Authentication
Start establishing a connection to LiquidPlanner in either of the following ways:
– or – - While working in a new or existing integration, you can add an application to a flow by clicking a source or destination. In the resulting Application list, select LiquidPlanner. Then, click the plus sign (+) to the right of Connection to edit the settings.
Authentication type: Basic
- Name: Required:Name the connection.
- Authentication Type: Required: Select Basic.
- Username: Required: Enter Username of your registered LiquidPlanner account.
- Password: Required: Enter Password of your registered LiquidPlanner account. The Passeord is created when the account is created.
- Borrow concurrency from (optional): Select another connection from the list....
- Concurrency level (optional): Up to 25 allowed....
Authentication type: Token
- Authentication Type: Required: Select Token.
- API Token: Required: Enter the API token. Use the following steps to get an API token:
- Log in to your LiquidPlanner account.
- Click on User Menu 🡪 My Settings
- Click My API Tokens🡪Add New Token to create a new token.
- This is the required API token.
