Shift4Shop documentation: API guide, Authentication
A. Set up a Shift4Shop connection
Start establishing a connection to Shift4Shop in either of the following ways:
In the resulting Application list, select Shift4Shop.
B. Supply required Shift4Shop account information
At this point, you’re presented with required options for providing Shift4Shop authentication.
Name (required): Provide a clear and distinguishable Name for the connection. Throughout integrator.io imports and exports, you will have the option to choose this new connection, and a unique identifier will prove helpful later when selecting among a list of connections that you’ve created.
Secure url (required): Provide the expected URL, according to your Shift4Shop account setup:
https://apirest.3dcart.com/3dCartWebAPI/<version>/<service>.
Private key (required): Enter your private key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s private key safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
Token (required): Enter the token generated for you by Shift4Shop. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
- Sign in to your account at devportal.3dcart.com.
- Open the Shift4Shop Developer Portal Dashboard, and select an app to edit.
- Show the Private key field, which is hidden by default.
- Scroll down to your stores at the bottom of the Developer Portal Dashboard to view and copy the token.
C. Edit advanced Shift4Shop settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Shift4Shop connection.
D. Test the connection
Once you have configured the Shift4Shop connection, you have a few options for continuing:
- Connect Shift4Shop (formerly 3dcart) to Anything
Integrate Shift4Shop, boost productivity, and unlock even more value from your business applications
