Handlebars helpers can be used to implement functionality that is not part of the handlebars language itself. The following list of helpers is supported by integrator.io:
Tip: Press the Home key to return to the top of this article (Fn + Left Arrow for Mac).
Custom helpers | Block helpers | Data variables | |
For a downloadable guide, see Handlebars helper reference (PDF format).
Custom helpers
abs
Returns the absolute value of a number.
{{abs number}}
number: This parameter can either be a field that returns a number value or a hard-coded number value.
Template | Context | Output |
{{abs field1}} |
123 |
add
Adds all numeric values (integers, floats, or decimals). Parameters can either be a field that returns a number value or a hard-coded number value.
{{add number1 number2 ...}}
- number1: Numeric field or hard-coded integer, float, or decimal.
- number2: Numeric field or hard-coded integer, float, or decimal.
Absolute values do not require context JSON variables. The example below only shows integers, but it also works with floats and decimals.
{{add item1 item2 item3}} |
144 |
{{add "2" "5" "2"}} |
9 |
{{add item1 "2" "3" item3}} |
138 |
avg
Computes the average of all specified numeric values (integers, floats, or decimals). Parameters can be either JSON fields or hard-coded values. Absolute values do not require Context JSON variables.
{{avg number1 number2 ...}}
{{avg item1 item2 item3}} |
48 |
{{avg "2" "5" "2"}} |
3 |
{{avg item1 "2" "3" item3}} |
34.5 |
aws4
Generates a signature for Amazon Web Services (AWS) and authenticates requests with AWS Signature Version 4. The authentication information is added to AWS API requests sent by HTTP.
{{{aws4 accessKey secretKey sessionToken region serviceName}}}
- accessKey: The access key for your AWS account.
- secretKey: The secret key for your AWS account.
- sessionToken: If your service does not require a session token use null or an empty string ("").
- region: Use an empty string (""), to calculate a default signature from the base URL.
- serviceName: Use an empty string (""), to calculate a default signature from the base URL.
For sessionToken, you can use null or an empty string ("") if a session token is not being used by the service.
{{{aws4 accessKey secretKey null region serviceName}}
For region and serviceName if you use null or an empty string (""), integrator.io calculates a default based on the base URL and then the signature is accordingly calculated.
{{{aws4 accessKey secretKey null null null}}}
The signature calculated in this case might not be the same as the signature calculated by AWS. Hence, we recommend that you provide values for region and serviceName.
Template |
{{{aws4 accessKey secretKey sessionToken region serviceName}}} |
Context |
Output |
<Signature> |
If the values are configured in the encrypted field of your HTTP connection, then you must provide the handlebar helper like this:
{{{aws4 connection.http.encrypted.accessKey connection.http.encrypted.secretKey connection.http.encrypted.sessionToken region serviceName}}}
Note: If you are using the authorization (aws4 handlebar helper) in the HTTP Authorization header of the request, you must also provide the X-Amz-Date header as shown below.
{{timestamp "YYYYMMDDTHHmmss" "Etc/GMT-0"}}Z
base64Decode
Decodes any Base64 string to the specified encoding format.
{{base64Decode base64String "decodeFormat"}}
- base64String: The encoded string value to be decoded
decodeFormat (optional): The optional binary-to-text encryption format to be decoded. This value can be any of the following:
- "ascii"
- "base64"
- "hex"
- "ucs2" or "ucs-2"
- "utf16le" or "utf-16le"
- "utf8" or "utf-8" (default)
- "binary"
- "latin1"
{{base64Decode str}} |
str = 'SGVsbG8gV29ybGQhIQ==' |
Hello World!! |
{{base64Decode str "utf8"}} |
{{base64Decode null}} |
{{base64Decode undefined}} |
{{base64Decode str "ascii"}} |
Hello World!! |
{{base64Decode str "binary"}} |
{{base64Decode str "hex"}} |
48656c6c6f20576f726c642121 |
{{base64Decode str str "utf8"}} |
Error: handlebars Helper {{base64Decode}} expects maximum 2 arguments only. |
{{base64Decode str |
Error: wrongEncodingFormat encoding format is not supported. |
base64Encode
Encodes the base64String field to the specified binary-to-text encoding format.
Note: Use triple-curly braces for this expression.
{{{base64Encode Base64String "encodeFormat"}}}
- base64String: The value to be encoded. This can be a field that returns string values or a hard-coded string.
encodeFormat (optional): The optional binary-to-text encryption format to be encoded. This value can be any of the following:
- "ascii"
- "base64"
- "hex"
- "ucs2" or "ucs-2"
- "binary"
- "latin1"
{{{base64Encode userName}}} |
dXNlcm5hbWU= |
{{{base64Encode userName pwd}}} |
dXNlcm5hbWVwYXNzd29yZA== |
{{{base64Encode userName ":" pwd}}} |
dXNlcm5hbWU6cGFzc3dvcmQ= |
capitalize
Capitalizes the first letter of the first word in a string.
{{capitalize field}}
The {{capitalize type}} is a |
The Dog is a |
{{capitalize day}} |
This is the day! |
capitalizeAll
Capitalizes the first letter of all the words in a string.
{{capitalizeAll field}}
Template |
On this day, the {{capitalizeAll type}} . . . |
Context |
Output |
On this day, the Dog, Wolf, Extant Grey Wolf . . . |
ceil
Returns the value rounded up to the nearest whole number.
{{ceil field}}
{{ceil item1}} |
46 |
dateAdd
Adds or subtracts the specified offset value from the specified date and returns the result in the specified time zone in ISO 8601 format.
{{dateAdd dateField offsetField timeZoneField}}
- offsetField: The amount of time in milliseconds to add to the date value. Prepend this value with a minus sign to subtract.
- timeZoneField (optional): Specifies the timezone. If not included in the expression, the time zone offset is not included in the resulting ISO timestamp.
Both of these fields are discussed in further detail below.
Note: not all of the fields in the default expression need to be present, as shown in some of the examples. See also: dateFormat and timestamp.
In this example, the timeZoneField is set to New York and the offsetField is shifted one day ahead (in milliseconds.) This will render the date one day ahead of what is in the Context. New York is -5:00 UTC, as shown in the output.
Template |
{{dateAdd dateOrders "107280000" "America/New_York"}} |
Context |
Output |
2019-12-15T00:48:00-05:00 |
dateField
In the first example below, the offset and timeZone fields have been removed and only the referenced object name:value pair in the Context file will be passed to the output.
The second example shows the offsetField set to one day behind, and is reflected in the output.
The third example shows the timeZone Field entered with no offset entered.
{{dateAdd dateOrders}} |
2019-11-05T15:25:00.000Z |
{{dateAdd dateOrders "-86400000"}} |
2019-11-04T15:25:00.000Z |
{{dateAdd dateOrders "" "America/Los_Angeles"}} |
2019-11-05T07:25:00-08:00 |
You can also enter a fixed date value in quotes:
{{dateAdd "Mon Nov 21 2019 20:08:40 GMT+0000"}}
Or you can add a standard date and the system will automatically format the output to ISO specification:
{{dateAdd "Nov 21, 2019"}} will output: 2019-11-21T00:00:00.000Z
offsetField
This field allows the date to be set to a hard-coded string.
Time values are expressed in milliseconds
- “86400000” = one day ahead (86,400,000 ms);
- "107280000"= two days ahead (107,280,000 ms);
- “-86400000” = one day behind (-86,400,000);
- Calculate milliseconds here
- Scientific notation may also be used: “1E6” = 1M (10^6 or 1,000,000 ms).
{{dateAdd dateOrders "86400000"}} |
2019-12-15T00:00:00.000Z |
{{dateAdd dateOrders "172800000"}} |
2019-12-16T00:00:00.000Z |
2019-12-13T00:00:00.000Z |
{{dateAdd date "3.888e+9}} |
"Wed Aug 08 2019 17:27:13 GMT+0530" |
2019-09-22T11:57:130.000Z |
Setting the date using offsetField
- The date offset in the first template is set to “86400000” (one day) and the output reflects the date as one day ahead of the dateOrders field in the Context; doubling this number will place the date two days ahead of the date in the value;
- The second example has the original offsetField value doubled “172800000” (two days);
- Conversely, placing a minus sign before the numeric value “-86400000” will subtract one day from the date.
- The fourth example uses scientific notation to increase a date value by 45 days. These offsets must be in milliseconds.
timeZoneField
This field uses standard ISO string date format where the offset value is subtracted from the specified date along with time zone. See integrator.io supported time zones.
Here, the offsetField is set to null “ ” which will output the time in Hong Kong local time which is +8 UTC.
{{dateAdd dateField "" "Asia/Hong_Kong"}}
Template |
{{dateAdd dateOrders "" "Asia/Hong_Kong"}} |
Context |
Output |
2019-12-14T08:00:00+08:00 |
The following examples show the conversion to UTC/GMT/Zulu time. Note that New York is -5 and Hong Kong is +8.
{{dateAdd dateOrders " "}} |
{{dateAdd dateOrders "" "America/New_York"}} |
019-11-05T10:25:00-05:00 |
2019-11-05T23:25:00+08:00 |
dateFormat
This helper allows the adjustment and transformation of time and date fields to be output in a particular format and altered according to your needs. The date and time fields are not all required in an expression, and they can be used in a modular fashion.
{{dateFormat o/pformat date i/pformat timezone}}
For current UTC and world time zones, see Wikipedia's list of tz database time zones.
The default date conforms to ISO specification:
- Structure: YYYY-MM-DD[T]hh:mm:ss.sss[Z]
- Output: 2019-11-12T21:02:32+00:00
- The date above is Nov 12, 2019, 1:02:32 PM PDT= 9:02:32 PM UTC
Time and date format codes:
- YYYY: four-digit year
- MM : two-digit month (01=January, etc.)
- DD : two-digit day of month (01 through 31)
- [T]: Time displayed as Coordinated Universal Time (UTC)
- HH: two digit hours (00 through 23)
- hh : two digit hours (01 through 12) Note: Use with a (am/pm) or A (AM/PM).
- mm: two digit minutes (00 through 59)
- ss : two digit seconds (00 through 59)
- SSS: one or more digits representing a decimal fraction of a second
- [Z]: expressed in Handlebars as "Zulu Time". If Z is present at the end of the date field, the time at this point will be expressed as Zulu time: +00:00
- a: am or pm
- A: AM or PM
For a complete list of all available time and date format codes, see Time and date format codes.
o/pformat
This field allows you to define the time and date format in the template which will be output accordingly. This field also works in concert with the "i/p format" field, which is discussed in further detail below.
Note: All date formats are placed in double quotation marks.
- “MM-DD-YYYY” = 01-01-2020
- “MM/DD/YYYY” = 01/01/2020
- “YYYY.DD.MM” = 2020.31.01
Template |
{{dateFormat "MM-DD-YYYY hh:mm" dateOrders "YYYY-DD-MM hh:mm"}} |
Context |
Output |
05-25-1966 10:36 |
date
This field passes the current date to the output unless specified in the context file. The following example shows how to print the current date in the format specified in the o/pformat field in the template.
{{dateFormat "MM-DD-YYYY" date}} |
02-26-2020 |
i/pformat
This field is the date object referenced in the Context. It can be hard-coded directly in the expression:
o/pformat vs. i/pformat:
- Output format (o/pformat) is where you define the desired output format
- Input format (i/pformat) is where you define the "input" format contained in the Context file
In the example below, the JSON Context format is "year/day/month" (1966/25/05). To output the date in the standard US format, define this format in the "o/pformat" field, as shown.
Template |
Context |
Output |
05-25-1966 10:36 |
timezone
This fields utilizes standard ISO string date format where the offset value is subtracted from the specified date along with time zone. See integrator.io supported time zones.
In the example below, note the "Z" in the o/p format field? this is telling the system to output the timezone assigned in the "timezone" field and adjust the time automatically for the chosen timezone-Los Angeles.
Template |
{{dateFormat "MM-DD-YYYY hh:mmZ" dateOrders "YYYY-DD-MM hh:mm" "America/Los_Angeles"}} |
Context |
Output |
05-25-1966 03:36-07:00 |
decodeURI
Decodes the specified URI. This example decodes the sample dataset from the “encodeURI” example.
{{{decodeURI field}}}
Note: This expression uses three curly braces.
Template |
{{{decodeURI orders}}} |
Context |
Output |
overseas order flow |
The URI may also be a “hard-coded” value declared in the expression.
Template |
{{{decodeURI "overseas%20order%20flow"}}} |
Context |
Output |
If you do not want the parameters inside the placeholder to be encoded (called escaping), use three brackets {{{ }}} - especially, when you intend to perform an encode/decode operation on the strings provided in the argument list (e.g. base64Encode or decodeURI).
HTML Encoded |
{{placeholder}} |
HTML and URL Encoded |
{{encodeURI field}} |
URL Encoded |
{{{encodeURI field}}} |
No Encoding Applied |
{{{ placeholder }}} |
divide
Returns the resultant quotient of two specified values. This helper returns the quotient of two variables, “hard-coded” values, or a combination thereof. Absolute values do not require context JSON variables.
{{divide field}}
{{divide item1 item2}} |
3 |
{{divide 2002 100}} |
20.02 |
{{divide item1 3}} |
11 |
encodeURI
This helper expression encodes the specified uniform resource indicator (URI), enclosed in three curly braces.
Certain characters are used to encode and are not allowed in the source value:
Tip: Call decodeURI to decode a previously encoded URI.
Template |
{{{encodeURI orders}}} |
Context |
Output |
overseas%20order%20flow |
The value may also be declared as a “hard-coded” in the expression with the same output:
{{encodeURI "sample data type"}}
floor
This helper is the inverse of ceil. Floor returns the largest integral value that is less than or equal to the specified number. Floor rounds down a value to the nearest whole number.
{{floor field}}
{{floor 22.44}} |
22 |
{{floor 45.25}} |
45 |
{{floor 3.14}} |
3 |
getValue
This helper returns the value from the specified field.
{{getValue field "defaultValue"}}
{{getValue "legends.unicorns" "defaultValue"}} |
11 |
{{getValue "legends.ponies" "defaultValue"}} |
22 |
{{getValue "legends.total" "defaultValue"}} |
null |
{{getValue "name" defaultValue}} |
Harry S Truman |
Note: The getValue helper method was introduced to retrieve the value from the complete path in the helper method's first argument. The getValue helper fails if used inside the #each block helper because getValue can't derive the complete path for the context of each data iteration.
"date": "2021-01-09",
"2021-01-09": "3"
To retrieve the value for "2021-01-09" (a dynamically generated field name based on another field value), the field name is unknown until the record is processed. You can use getValue to identify that field name by looking at the value for the "date" field.
{{getValue (getValue "date")}}
Another example would be as follows:
"hours": {
"2021-01-09": "3"
Since getValue is a helper method, you can nest other helper methods inside it, which opens up multiple options for dynamically generating the field name.
{{getValue (join "." "hours" (getValue "date"))}}
hash
Use this handlebar helper to cryptographically encode field values.
{{hash algorithm encoding field}}
{{{hash "md5" "base64" name}}} |
sGiTHMRQRCtj9bPSdupClw== |
{{{hash "md5" "hex" name}}} |
b068931cc450442b63f5b3d276ea4297 |
See Supported cryptographic encoding algorithms.
hmac
Keyed-hashing for message authentication (HMAC) is a message authentication code generated via cryptographic hash function (such as MD5, SHA-256 and many more). This crypto key wraps the data until it is authenticated using a shared key. For a complete list of integrator.io support, see Supported cryptographic encoding algorithms.
{{hmac "algorithm" key "encoding" field keyEncoding}}
- algorithm - accepts any integrator.io supported cryptographic encoding algorithm.
- key - the path to the encryption key (in dot notation).
- encoding - encoding type of the sent key ("hex" or base64").
- field - the path to the incoming parameter (in dot notation).
- keyEncoding (optional) - encoding type of the incoming key (currently only supports utf8 and base64). By default, incoming key encoding is assumed to be in utf8 format.
In this example, the key would be your secret key, or private access key.
Note: Be cautious about exposing the secret key, potentially compromising your system credentials.
Connection details:
- HTTPS should be used, where standard HTTP should be avoided wherever possible
- All PARAMETER values must be URI encoded
- Authorization HEADER {{hmac}} helper must use the "full URL" keyword as the input as the system will calculate the signature based on the complete URL that it receives, including PARAMETER values and the Base URI https
See Using hmacOptions for additional functionality.
join
Joins field names using the specified delimiter and can handle any number of arguments.
{{join delimiterField field1 field2}}
delimiterField: The delimiter character(s) inserted between joined field names. Can be (parentheses) {braces} [brackets] or /*
Notes:
- If a delimiter array is specified, the specified delimiter is introduced between each array value in the result set
- If a string is specified, the specified subsequent variables are read and the specified delimiter is introduced between them in the result set
{{join "**" "unicorns" "ponies"}} |
unicorns**ponies |
{{join " + " "unicorns" "ponies" "horses"}} |
unicorns + ponies + horses |
{{join "-" "unicorns" "ponies" "horses"}} |
unicorns-horses |
{{join "-" "legends" "[unicorns, ponies, horses]"}} |
legends-[unicorns, ponies, horses] |
{{join ", " sundayDrivingMusic}} |
"Iron Maiden, DIO, (old)Metallica, Snoop" |
jsonEncode
Encodes the specified JSON object.
{{jsonEncode field}}
{{jsonEncode total}} |
99.99 |
jsonSerialize
The jsonSerialize function converts an object value into a JSON serialized string. Three curly braces are used in this expression.
{{{jsonSerialize field}}}
Template |
{{{jsonSerialize elementals}}} |
Context |
Output |
{gnomes:"677",salamanders:"422",sprites:"56",faeries:"277"} |
lookup
This expression can only be used to reference a static or dynamic lookup that has been previously created in the current flow step by lookup name. Note that you can't use this expression to reference lookup flow steps or lookups created in other flow steps.
Dynamic mapping:
{{lookup.<lookup name>}}
Ex:
{{lookup.typeLookup}}
Static mapping:`
{{lookup '<lookup name>' this.<Export Field Name>}}
Ex:
{{lookup 'vendor_status' this.ExportFieldName}}
lowercase
Converts all letters in a string to lowercase.
{{lowercase field}}
Template |
{{lowercase 'HERE WE GO!'}} |
Context |
Output |
here we go! |
multiply
Returns the multiplication of the two specified values. Variables may be referenced in context, or as “hard-coded” values.
{{multiply field}}
{{multiply unicorns "5"}} |
55 |
{{multiply "5" "2"}} |
10 |
{{multiply horses ponies}} |
726 |
{{multiply Field1 -1}} |
22211.4 |
random
Generates a random alphanumeric string with an optional input field for the length. The first argument must be either “crypto” or “uuid”, and the default length is 32 characters.
Note: When mapping to NetSuite, you can also pass "number" as the first argument. The output will be a numeric string (instead of an alphanumeric string): {{random "number" 9}}
{{random "crypto" length}}
or
{{random "uuid" length}}
- "crypto" or "uuid": the method for random alphanumeric string generation
- "length": integer value for the number of characters in the output
{{random "uuid" 5}} |
5e3ca |
{{random "crypto" 8}} |
4ccb3420 |
regexMatch
Matches the input data based on the regular expression and returns the data based on index and options variables.
{{regexMatch field regex index options}}
- field: the field name containing the variable or values to be matched against. For example, CustomerID would be the field name containing the string value you are running the regex match request on. You can reference a field or variable by typing its name without double quotes (or curly braces or parens).
- regex: the regular expression pattern to match against existing values. For example, if your regex pattern is [a-zA-Z][0-9][0-9], a match occurs the first time any capital or lowercase letter is immediately followed by two numeric characters.
- index: the location of the numerical range to be examined when searching for matches returned. For example, if your regex pattern is [0-9][0-9][0-9], matches will occur the first time three consecutive numeric characters are adjacent in the field value. The index defaults to 0. If you enter an index value of 1, you will only match on the second occurrence of three adjacent number characters.
options: modifies the search flag of the expression. For example, regular expressions stop at the first match in the text content by default. The "g" flag indicates that the regular expression should be tested against all possible matches in a string. See Advanced searching with flags.
- d - Generate indices for substring matches.
- g - Global search.
- i - Case-insensitive search.
- m - Allows ^ and $ to match newline characters.
- s - Allows . to match newline characters.
- u - "Unicode"; treat a pattern as a sequence of Unicode code points.
- y - Perform a "sticky" search that matches starting at the current position in the target string.
{{regexMatch secretCode "7" "[0-9]"}} |
7 |
{{regexMatch secretCode "007" "[0-9]"}} |
007 |
{{regexMatch secretCode "[0-2][0-2][5-7]"}} |
007 |
{{regexMatch secretCode "[0-9][0-9][0-9]" 1 "g"}} |
345 |
regexReplace
The regexReplace helper returns a modified string where the pattern has been replaced.
{{regexReplace search replacement regex options}}
- search: the value or field name to be replaced. You can reference a field or variable by typing its name without double quotes (or curly braces or parens).
- replacement: the new value that will replace the matching value in regex.
- regex: the regular expression that you’re searching for.
- options: modifies the search flag of the expression. For example, regular expressions stop at the first match in the text content by default. The "g" flag indicates that the regular expression should be tested against all possible matches in a string. See Advanced searching with flags.
In this example, the output has the word “Sequence” replacing the number 6 in the Context.
Template |
{{regexReplace secretCode "Sequence" "[6]"}} |
Context |
Output |
12345Sequence7890 |
Alternately, you could change the price of an incorrect value by entering the number to change and assigning the value of the overwrite. Here, we have modified $249.99 to $549.99 and $9.99 to $19.99 respectively.
{{regexReplace total "5" "[2]"}} |
$549.99 |
{{regexReplace total "19" "[9]"}} |
$19.99 |
You can use the following regexReplace expression to remove leading zeros from a field value.
{{regexReplace id "" "^0+" "g"}} |
157 |
See also Regular expressions (regex).
regexSearch
The regexSearch helper uses an expression to search for a match, and returns the position of the result in the dataset, where 0=first position and 2=third position.
{{{regexSearch field regex options}}}
- field: the field name containing the variable or values to be replaced.
- regex: the new value which will replace the existing value.
- options: modifes the search flag of the expression. For example, regular expressions stop at the first match in the text content by default. The "g" flag indicates that the regular expression should be tested against all possible matches in a string. See Advanced searching with flags.
Template |
{{regexSearch total 5}} |
Context |
Output |
7(where 5 is the eighth value (INDEX location=7) in the “total” JSON field value) |
replace
Replaces all the occurrences of the specified letter in a string with another letter.
{{replace field string string}}
{{replace cases "&" "and"}} |
these and those and some other cases |
{{replace description "Shoes" "Boots"}} |
Boots |
round
Rounds a decimal number value up or down to the nearest whole number value.
{{round field}}
Template |
{{round vat}} |
Context |
Output |
30 |
sort
This helper sorts the specified values in ascending or descending order based on the value specified in the ”reverse” parameter. By default, this helper sorts the array variables in an ascending manner. If the input array contains numerical variables for sorting, set the number parameter = "true". You can also combine reverse and number option parameters in the handlebars expression.
{{sort field number="true" reverse="true"}}
{{sort items number="true"}} |
1,2,3,4,5 |
{{sort items reverse="true"}} |
5,4,3,2,1 |
{{sort items}} |
candy,hat,toy |
split
Splits a series of words separated by delimiters in the context based on an index value, where 0=first position and 2=third position.
{{split field delimiter index}}
{{split fullName "-" 0}} |
Hillary |
{{split fullName "-" 1}} |
Ann |
{{split fullName "-" 2}} |
Swank |
Hillary |
subtract
Returns the remainder of two values.
{{subtract minuend subtrahend}}
These are just mathematical terms for:
{{subtract value value}}
You can subtract the values of two fields, integers, or strings in this handlebars expression. If you are passing fields or integers, do not use quotes. If you are using string values, make sure to use quotes.
{{subtract "6" "3"}} |
3 |
{{subtract 6 3}} |
3 |
{{subtract "6" ponies}} |
-16 |
{{subtract horses "6"}} |
27 |
{{subtract ponies unicorns}} |
11 |
substring
Returns a substring of the specified string. This is useful for shortening the names of longer field names.
{{substring stringField startIndex endIndex}}
- stringField is the actual string
- startIndex is index of the actual at which the substring starts, where 0=first position and 2=third position
- endIndex is the index of the actual string where the substring ends, where 0=first position and 2=third position
- endIndex acts like JavaScript and is non-inclusive
{{substring "itemizationCode" "0" "4"}} |
item |
{{substring "inventory" "0" "3"}} |
inv |
{{substring memo "10" "19"}} |
{"memo": "The quick brown fox jumped over the lazy dog"} |
brown fox |
Note: Don't encase an object name in quotes when using substring to reference its value.
sum
Computes the sum of all numbers present in the specified array. The example below only shows integers, but it also works with floats and decimals.
Note: this is different from the add helper function and performs additional calculations.
{{sum field1 field2 field3}}
{{sum items}} |
31 |
{{sum items}} |
290 |
{{sum (multiply 2 55)}} |
110 |
timestamp
Returns a timestamp in the format and timezone provided.
- If no timestamp format is provided, this function defaults to ISO8601.
- If no timezone is provided, this function uses the timezone set in your profile settings. If your profile has no timezone set, the server's configured timezone is used.
{{timestamp format timezone}}
The first example below shows the local time in Los Angeles, which is 09:27:46 (HH:MM:SS), but is followed by the Zulu time offset (-08:00).
In the second example, the current time is displayed in Zulu time (as the server is configured).
{{timestamp HH:MM:SS "America/Los_Angeles"}} |
2021-02-05T09:27:46-08:00 |
{{timestamp HH:MM:SS}} |
2021-02-05T17:38:20.715Z |
toExponential
Returns a string representing the specified number in an exponential format. Variables may be referenced in context or as “hard-coded” values.
{{toExponential field fractionDigits}}
- field: is the number or object value to be modified;
- fractionDigits: an optional parameter that will display the provided number of digits after the decimal place.
{{toExponential orderId 2}} |
1.23e+4 |
{{toExponential "12345" 2}} |
1.23e+4 |
{{toExponential "3.14159265359" 6}} |
3.141593e+0 |
toFixed
This will set a fixed numerical value to the output string, and format the number to a fixed number of decimal places.
{{toFixed field digits}}
- field: the number to be modified
- digits: number of decimal places to be displayed
{{toFixed 123.456789 0}} = 123
{{toFixed 123.456789 1}} = 123.5
{{toFixed 123.456789 2}} = 123.46
{{toFixed 123.456789 3}} = 123.457
{{toFixed 123.456789 4}} = 123.4568
{{toFixed 123.456789 5}} = 123.45679
toPrecision
This outputs scientific notation if there are more integer digits (before decimals) than the specified precision.
{{toPrecision field precision}}
- precision: number of decimal places to be displayed
{{toPrecision 123.00 0}} = 1e+2
{{toPrecision 123.00 1}} = 1e+2
{{toPrecision 123.00 2}} = 1.2e+2
{{toPrecision 123.00 3}} = 123
{{toPrecision 123456.00 5}} = 1.2346e+5
{{toPrecision 1234567.00 6}} = 123456
trim
This helper will remove (trim) any white space in a Trims whitespace characters present at the beginning and at the end of the string.
{{trim field}}
Use the trim field if you have white space that persists in your file across all values. Here, the whitespace is before the “artist” value as seen in the output like this:
The problem is also evident in the context below, and the example shown in the Template will resolve the white space issue in the output.
{{trim library.artist}} |
Lalo Schifrin |
uppercase
Converts all lowercase characters in the JSON field value or string to uppercase.
{{uppercase field}}
{{uppercase "library"}} |
LIBRARY |
The {{uppercase family.type}} is a member |
The DOG is a member |
Block Helpers
Block helpers have a hash symbol at the beginning.
#and
The #and block helper renders the expression if both of the specified parameters are true (according to JavaScript rules). If the result is false, the {{else}} expression prints in the output. If the field is undefined, null, or an empty string, it will evaluate as false, otherwise it will be true. The integer value of 0 will evaluate to false; however, the STRING value of "0" evaluates to true, as all non-empty strings are true:
{{#and field field}} expr {{else}} expr {{/and}}
1. {{#and Contact.homeAddress Contact.offAddress}}true{{else}}false{{/and}} |
1. true |
{{#and legends.unicorns |
11-33 |
{{#and firstName lastName}} |
Hillary Ann |
#compare
The #compare block helper compares two variables using a logical operator.
{{#compare field operator field}} expr {{else}} expr {{/compare}}
The compare helper compares data variables against each other using logical operators. The "else" statement is used to output text if the argument returns a false condition.
Template |
{{#compare details.fromState "===" "NE"}}+{{details.qty}} |
Context |
Output |
+3 |
The second argument is the arithmetic operator to be used for comparing the two arguments. Optionally, you can also specify the {{else}} expression to render the value when #compare returns FALSE.
In the following example, reversing the operator will change the output to “false.”
Template |
{{#compare sample1 ">" sample2}} true {{else}} false {{/compare}} |
Context |
Output |
true |
This example shows a comparison of the quantity on hand against the quantity ordered, and logical output.
Template |
{{#compare qty ">=" ordered}}Please ship {{qty}} units |
Context |
Output |
Please ship 100 units |
This example uses compare to verify a phone number field has exactly 10 digits. If not, the output is ten zeros (0000000000).
Template |
{{#compare phone.length "===" 10}}{{else}}0000000000{{/compare}} |
Context |
Output |
0000000000 |
Logical Operators for #compare
Operator | Description |
< | Less than (a < b) |
> | Greater than (a > b) |
<= | Less than or equal to (a <= b) |
>= | Greater than or equal to (a >= b) |
Equal to (a == b) If the two compared values are not of the same type (string, boolean, or number), this operator will attempt to convert the values to like types. |
Strict equal to (a === b) If the two compared values are not of the same type (string, boolean, or number), this operator will NOT attempt to convert the values to like types. No type conversion is done, and the types must be the same to be considered equal. |
Not equal to (a != b) If the two compared values are not of the same type (string, boolean, or number), this operator will attempt to convert the values to like types. |
Strict not equal to (a !== b) If the two compared values are not of the same type (string, boolean, or number), this operator will NOT attempt to convert the values to like types. No type conversion is done, and the types must be the same to be considered equal. |
Note: You can reference literal strings in compare statements by surrounding the literal string in double quotation marks. For example: {{#compare record.Domain "==" "eu.integrator.io"}}
Compare with else
This example shows the #compare block helper with a nested compare expression. The sample compares the quantity order with current inventory levels. It then compares the current inventory levels with items on order. If the order can be successfully filled, the expressions return “Match”. If not, the output returns “Inventory levels too low”.
Template |
{{#compare ordered "<=" stockLevel}}Match{{else compare stockLevel "<" |
Context |
Output |
Match |
#contains
The #contains block helper parses the name:value specified in the block to check for the presence of a given value. If the value specified is not present, then it prints the {{else}} expression.
{{#contains fieldArray field}} optionalTextIfTrue {{else}} optionalTextIfFalse {{/contains}}
The fieldArray value can be an array name, arrayname.keyname, or a string that will be interpreted as an array.
In the first example, the order.item value is “12345”. The specified value in the #contains block is “5”. Since 5 is a number present in the value, the first expression statement will be displayed. The second example is looking for a “6”. Since 6 is not present, the else statement it output.
{{#contains order.item "5"}} |
Sales ID Found! |
{{#contains order.item "6"}} |
Sales ID Missing! |
{{#contains order.sales "2"}} |
Sales ID Found! |
The example below shows an if/then argument against the product and whether or not a product warranty was purchased via an if...else argument against the context fields specified.
Template |
{{#contains ERP_Item "kit"}}+1{{else}}None found{{/contains}} |
Context |
Output |
+1 |
The example below uses #contains expression nested inside of an if/else expression to set a field to true if another field contains a specific string. In this example, the source_name field contains "3.1415926". If the value for source_name does not contain "3.1415926", the field is set to false.
Template |
{{#if source_name}}{{#contains source_name "3.1415926"}}true |
Context |
Output |
true |
#each
This helper allows you to iterate over a list. Inside the #each block, you can reference the element to be iterated over.
{{#each field}}{{this}}{{/each}}
This example shows a simple record with names. The {{each}} expression will reference the context while the {{this}} expression will iterate over the array of items in the [people] array.
For the example below, in integrator.io, the [people] array must be referenced as an absolute path in the Resource path field. If the context was an object (name:value pair), then the path would not need to be set.
Also in this example, the semicolon and space between the expressions will allow spacing and punctuation between the variables on output.
Template |
{{#each people}}{{this}}; {{/each}} |
Context |
Output |
Bertram Gilfoyle; Erlich Bachman; Jin Yang; |
This example shows the system iterating over the array in the "field.names" variables.
Template |
{{#each fields.names}}{{#each this}} Employee {{@key}}: {{this}} |
Context |
Output |
Employee name1: Stacy |
When looping through items in #each, you can also reference the current loop index.
Template |
System privilege levels: {{@index}} |
Context |
Output |
System privilege levels: |
Additionally for iterating over objects, {{@key}} will reference the current key name. @key will
provide the current index location in an array or the key names in the Context.
Template |
{{#each fields.rights}} |
Context |
Output |
0:system; 1:admin; 2:editor; 3:contributor; 4:viewer; 5:vendor; |
The first and last steps of iteration are noted via the @first and @last variables when iterating over an array. When iterating over an object, only @first is available. Nested #each blocks may access the iteration variables via depth based paths. To access a parent index in a nested #each loop, specify @../index.
The each helper also supports block parameters, allowing for named references anywhere in the block.
Template |
Context |
Output |
To create a list or convert data based on index location in a record, you can declare an |item| using vertical bars (pipe character), then entering the characters by their respective index locations (where 0=first character).
Template |
{{#each inventoryItems as |item|}} |
Context |
Output |
1: a |
#if...else
The #if _else helper allows an if/then argument.
{{#if field}}expr{{else}}expr{{/if}}
If the argument in the {{#if field}} is true, then it prints the value from the context. If the argument is false (either undefined, null, " ", 0, or [ ] ), then the block prints the else condition.
Important: Do not use spaces in this expression.
If Else logical operators
The following logical operators may be used for building an argument or placing arguments inside expressions.
if |
If a specified condition is true, this specifies a block of code to be executed If the condition is false, another block of code can be executed. {{#if data.name}}{{data.name}}{{/if}} |
if...else |
This statement is a part of JavaScript's "Conditional" Statements, which are used to perform different actions based on different conditions, and will execute a block of code if a specified condition is true. {{#if Name}}{{Name}}{{else}}{{/if}} |
else | Specifies a block of code to be executed if the same condition is false. |
else if |
Specifies a new condition to test if the first condition is false. |
compare |
Compares two values using logical operators. {{#compare field operator field}} expr {{else}} expr {{/compare}} |
each |
{{#each data.identity-profiles}} {{vid}} {{/each}} |
if...compare |
{{#if data.name}}{{#compare data.name "!=" |
#ifEven
This argument checks to see if a given value is an even number.
{{#ifEven field}} expr {{else}} expr {{/ifEven}}
If the argument results in an even number (true), the value prints to output. If the argument results in an odd number (false), the {{else}} expression displays. A blank expr field prints the value unless text is specified, as shown below.
{{#ifEven orders.item1}} |
2 |
{{#ifEven orders.item2}} |
Odd number value |
{{#ifEven orders.item3}} |
The even number value is 8 |
#neither
This helper is used for building true/false arguments.
{{#neither field field}} expr {{else}} expr {{/neither}}
- If both parameters are equal to false, the first expression displays.
- If one or both are equal to true, the {{else}} expression statement displays.
In this example, both the values in the Context are blank /null (which makes the argument true), so the first expression is printed to output.
Template |
{{#neither item1 item2}} |
Context |
Output |
Values are absent for the specified parameters. |
In this example, only one of the Context variables is blank, so the argument will pass the {{else}} statement to the output.
Template |
Context |
Output |
Only one of the parameters has a value. |
#or
This helper creates an all-or-nothing argument. It prints the first expression if the argument is true, and the {{else}} expression if the argument is false.
{{#or field field}} expr {{else}} expr {{/or}}
{{#or item1 item2}} |
One or both fields have a data value. |
Neither field has a data value. |
#unless
The #unless helper is the inverse argument of the #if block helper. The #unless block renders if the #unless expression returns a false value.
{{#unless field}} expr {{else}} expr {{/unless}}
{{#unless contact.phone}} |
Contact phone number is: |
Phone number missing |
#with
The #with helper demonstrates how to pass a parameter to your helper. When a parameter calls a helper, it is invoked with whatever context the template passed in. This allows access to nested objects in the context without having to repeatedly type the parent name in each expression.
Template |
{{#with library}}{{title}} on "{{album}}" by {{artist}} {{/with}} |
Context |
Output |
Danube Incident on "The Sound" by Lalo Schifrin |
The with helper passes a parameter to a helper.
{{#with field}} {{field1}} {{field2}} {{/with}}
When a parameter calls the helper, it invokes the context from the template.
Template |
The author{{#with author}} {{firstName}} {{lastName}}{{/with}} |
Context |
Output |
Output The author Charles Dickens |
Nesting block helpers
The following expressions describe the expression format and samples for block helpers. Variables and “hard-coded” values may be nested and referenced.
Template |
{{#if contact.phone}}{{contact.phone}} |
Context |
Output |
310-555-1234 |
Block helpers may also be nested, as shown below.
Template |
{{#compare customer1 "==" "2"}} |
Context |
Output |
True |
Raw blocks
Raw blocks are virtually the same as block helpers; however, child content is treated as a literal string.
{{{{name}}}} |
{{Samantha}} |
data variables
root
Reference the @root data variable to access the root element properties while you iterate in the context of any nested or child elements. The following scenarios illustrate @root with sample JSON.
{{@root.title}} |
My New Post |
{{#each array}}{{@root.title}} |
My New Post |
{{@root.child.childTitle}} |
Child Title |
key
This data variable provides the current index location in an array or the key names in the context. The key is the index value of the array. When iterating through values in an array, the output always starts with 0.
{{#each array}} |
0 1 2 3 |
{{#each array}} {{@key}} {{/each}} |
{ "title": "My New Post", "body": "This is my first post!", "array": ["one","two","three","four"], "message": "This is the message.", "child": { "childTitle": "Child Title", "childBody": "Child Body" } } |
0 1 2 3 |
{{#each @root.child}} |
childTitle |
{{#each @root}} |
title body array |
index
This data variable gives you the current index in an array iteration or in a JSON iteration in the context of #each.
0 1 |
{{#each @root.people}} |
0 1 2 |
first
This data variable returns true for the first element of an array or an object. When iterating through values in an array, the output always starts with 0.
childTitle |
{{#each array}} |
0 |
{{#each array}} {{#if @first}} {{@key}} {{/if}} {{/each}} |
{ "title": "My New Post", "body": "This is my first post!", "array": ["apple","orange","pear","banana"], "message": "This is the message.", "child": { "childTitle": "Child Title", "childBody": "Child Body" } } |
0 |
last
This data variable returns true for the last element of an array. When iterating through values in an array, the output always starts with 0. In a nested loop, refer to the immediate parent with the index @../last, and so on.
Note: This helper is not available when iterating over an object.
childBody |
{{#each array}} |
3 |
{{#each array}} |
3 |
this
The this keyword refers to different objects, depending on how it’s invoked (used or called).
You can use the this expression in handlebars to reference the current context. Within a block helper, this refers to the element being iterated over. While iterating an object, this refers to the complete object. While iterating an array, this refers to a complete array. We have to use {{#each this}} to refer to individual elements in an array.
[ {{#with data}} {{#each this}} {{#if @index}}, {{/if}} { "firstName" : {{this.name}}, {{#each this}} “{{@key}}”: “{{this}}” {{/each}} } {{/each}} {{/with}} ] |
{ "data": [ { "name": "John", "id": 1 }, { "name": "Leslie", "id": 2 } ] } |
[ { "firstName": "John", "Name": "John", "id": 1 }, { "firstName": "Leslie", "name": "Leslie", "id": 2 } ] |
This example shows a simple dataset with two names. The first {{#each this}} references the objects in the data array. So, in this case, we’re referring to each object in the array.
"data": [
"name": "John",
"id": 1
"name": "Leslie",
"id": 2
The second use of {{#each this}} references each element of the object. That would be the key: value pairs in each object.
"data": [
"name": "John",
"id": 1
"name": "Leslie",
"id": 2
The third use of {{this}} references the value of the key: value pair.
So, the final output would be
length
Counts the length of a given string for use in other functions.
This example counts the length of the state field. If the length is exactly two characters, integrator.io capitalizes the output. If the length is not exactly two characters, the output is "Bad state value".
Template |
{{#compare state.length "===" 2}}{{uppercase state}}{{else}}Bad state value{{/compare}} |
Context |
Output |
Bad state value IL |
This example uses length with the compare handlebar to verify a phone number field has exactly 10 digits. If not, the output is ten zeros (0000000000).
Template |
Context |
Output |
0000000000 |
68 comments
Thank you for the reference! Where can I find a list of options for the "options" parameter for regexMatch?
Hi Tony, I've updated the article to link to this resource for regex options: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Guide/Regular_Expressions. I hope that helps. Thanks for the feedback.
Is there an example for the #switch syntax? It's the only block logical operator that doesn't have any hint as to the syntax.
Hi Jeff Dollard,
Thanks for providing this feedback! We're looking into this for you.
The substring description for the end index doesn't match the behavior. The end index acts like javascript and it's non-inclusive. That should be noted above. This was baffling me for a bit. How did this {{substring "itemizationCode" 0 4}} return "item" ??
Hi David Gollom,
Thanks for letting us know - I updated the article with this note. Is there anything else we should add based on your findings? Thank you so much for your help!
Hi Jeff Dollard,
We haven't found any information on the switch handlebars. Have you had any luck?
Hi Courtney - no luck with the switch syntax, I sort of gave up on guessing at it ¯\_(ツ)_/¯
I found another way to structure my logic, so it didn't keep me from moving forward.
Awesome, glad to hear it, Jeff Dollard! Any cool tips you can share that we could add to the docs?
Shouldn't the output be "123 Anywhere789 Somewhere"? Both have values.
Hi APC DSR,
This image describes why the expression evaluates to false:
We've revised the example for clarity.
Thank you so much for letting us know how we could improve the article, APC DSR! Please let us know if there are other things we can add! We've also added more examples to the #and section. Hope they're helpful!
Jeff Dollard
I want to let you know that the "Switch" syntax is not supported. We are updating this KB. Thanks for bringing it to our attention!
Do sum and add helpers only work with integers or can they be used with decimals/float values?
Hi Jeff Dollard,
That's a great question and we'll update our article accordingly. I just tested this and decimals and floats seem to work fine for both add and sum. Let us know if you run into any issues!
I'm trying, but I don't understand the purpose of getValue,- why not just reference the field directly?
Apparently there is a second parameter with "default value" used in the example, but I don't how it's used.
Why does the following example return null? I would expect either an empty string or... "default Value"
Anyway, I was reading this page (again) and stopped on getValue to learn about it and after failing to do so I thought I'd leave this comment.
The regexReplace section seems to be missing something in the template. It should read {{regexReplace field replacement regex options}}. I'm not sure about the index bit. There's reference to an index parameter but I wasn't able to get that to work. Thanks!
Hi, Steve Klett. That's a great question. After conferring a bit, we realized that this description indeed needs clarification, and there are some scenarios where {{getValue}} is your "helper" after all.
Not sure what level of feedback is actually wanted by the Celigo team, this may be considered petty - if so, tell me offline.
The subtract documentation states:
This is inaccurate, you can use Number types rather than strings.
The description also shows the syntax as
seems like
would be more general.
David Gollom, your post is consistent with the examples and every regexReplace usage/result that I've seen.
I suspect that that was a copy-paste error from {{substring}}, waiting many months for your careful read. We'll review and update. Thanks much!
Hi Steve Klett,
Never would we turn down your valuable help! We really appreciate you sharing this with us. I've made updates to the subtract section. Please let us know if you notice anything else we should change. Thank you so much for your help!
Thanks, Steve Klett, for the non-petty feedback. This is the right place, for other readers, as well.
Your uses of {{subtract}} are correct, and the examples in the article would benefit from demonstrating additional data types, which we'll add.
A couple points of clarification:
The behavior of @last with objects seems to be the negative of @first. I.e. An object with 3 keys will return true for @last for the 2nd and 3rd key. Is that expected?
Hi Stephen, I missed an important note in the documentation: "The first and last steps of iteration are noted via the @first and @last variables when iterating over an array. When iterating over an object only the @first is available."
The behavior I was seeing was when iterating over an object.
Hi Stephen Lemp,
Thanks for calling our attention to this area for potential confusion. We've added an example and added information on the zero-indexing of arrays to the @first, @last sections. Please let us know if there are other ways we could improve this documentation!
Thanks for the clarification, Stephen Lemp. I was able to reproduce that problem with this simple object, and indeed @last evaluated to true on every inner loop after the first.
Poking around at handlebars resources online, it seems that iterating through nested objects is not roundly and fully supported. Assuming that you're trying to check @last in order to properly format the JSON in a template, I appealed to a support lead here, who came up with a clever solution: add the comma before printing the array based on the value of @first instead.
Your use case is doubtless more complex, but let me know if that's not what you need or if we should look into the problem further.
Stephen Brandt Thank you so much - that's exactly what I needed! I had resorted to getting the number of keys (number_of_keys) with JavaScript and printing the comma if @index != number_of_keys. Your solution is much cleaner and I can get rid of the convoluted JavaScript logic :D. Thanks again! The use case here is actually taking an object and creating a SQL INSERT INTO statement. SQL is picky about the commas, just like JSON though, so essentially the same.
Hello Celigo,
is there a way how to register new custom Handlebars helper?
I've came to the handlebars engine limitation when I cannot use if helper inside multiply helper.
I've found workaround for that with custom helper, however I do not know how to register it.
My case:
when I want to do sum of tax rates but only when tax amount is greater than zero... For instance, you can have four different tax rates in US, however for shipping only two-three of them are applied, but in the payload all four are available so I want to filter out rates with zero amount.
origin handlebar without conditions:
part of the payload regarding "shipping_lines":
as you can see the tax code with a name "IL CITY TAX" has rate 0.01 however amount is zero, which leads into miscalculation in the accounting system when imported shipping tax rate is 8% instead of 7%
So I've added conditions to check tax amount/price at the first place and then do sum of rates when tax amount is greater than zero:
Unfortunately, I always get an error: " Could not compile handle bar ... Parse error on line 4 ... Expecting 'ID', 'STRING', 'NUMBER', 'BOOLEAN', 'UNDEFINED', 'NULL', 'DATA', got 'OPEN_BLOCK'"
So I've created custom helper which is easy to use on the page tryhandlebarsjs.com or jsfiddle.com, but not able to use in celigo mapping:
You would then use the helper in your template as a Handlebars Subexpression, which allows you to nest helpers:
How can I offset one day back to the current date.
I want to have a date like if the current date is 05/06/2021 then it should be with offset '-1' 05/05/2021.
Thanks
Hi, Harish Bakka.
[Updated thread...]
There is a little known keyword that seems to be the right answer to retrieving the current date. Then, you'd subtract the number of milliseconds in 24 hours to get yesterday's date, formatted as above:
I trust it will also resolve correctly in your import mapping. Thanks for your patience while I did a little more digging.
