Token-based authentication is stateless, which means that neither the server nor the session stores any information about the user. The token is sent on every request, helping to prevent cross-site request forgery attacks. For added security the token expires after a set amount of time.
You can build integrations with apps that use HTTP even if the connection is not already provided by Celigo integrator.io.
Before creating the connection, review your app’s API guide. It should provide the information you need, such as the kind of authentication that the app requires and its URI.
Contents
- A. Create the HTTP connection
- B. Name the connection and choose its mode
- C. Describe the connection
- D. Configure token authentication
- E. Edit common HTTP settings (optional)
- F. Save, test, and authorize
- Sign in to integrator.io.
- From the Tools menu, click Flow Builder.
- When exporting data from this app, click Add source.
– or –
When importing data into this app, click Add destination/lookup. - Click HTTP from the list of application types.
- Next to Connection, click the create icon.
Note: For on-premise mode, an agent must first be installed and configured. If the system you want to connect to is behind a firewall, the agent helps connect without having to whitelist any IPs.
Name (required): Give your connection a name that is meaningful to your integration and that can help you identify it later in a list of connections.
Mode (required): Choose one of the following:
- Cloud: Connect to an app in the cloud.
- On-premise: Connect to an an on-premise app, which runs locally on the company’s servers.
From the Agent dropdown, select an installed agent.
Provide the application details.
Configure HTTP headers (optional): Click this button to pass additional parameters in the header. Configure any headers as needed for your integration, providing the names and values in the resulting editor.
Base URI (required): Enter the base URI, which is the path to the app’s API, as documented in the API guide.
Media type (required): Choose the format for your records.
- Success media type (optional): Select the type of content expected when a response succeeds (such as XML or JSON).
- Error media type (optional): Select the type of content expected when an error occurs.
Enter the token details.
Authentication type (required): Select Token.
Token (required): Enter your API token. Multiple layers of protection (including AES 256 encryption) are in place to secure your API token.
Location (required): Referring to the app's API documentation, select where the API expects to find the authentication token. Additional options may appear specific to that location:
- URL Parameter
Parameter name (required): Enter the name of the URL parameter that holds the API token value. For example, if you enter myAPITokenURLParam, then all HTTP requests will include
?myAPITokenURLParam=[token]. - Header
Header name (optional): By default, integrator.io will send all authentication info in the authorization HTTP header field. If the application you are connecting to requires a different HTTP header, enter the name here.
Scheme (required): Select an authentication scheme, per the API documentation.
If the API you are connecting to doesn't follow the HTTP specs for the authentication scheme exactly, select Custom and enter a Custom auth scheme. - Body
Configure token refresh(optional): Check this box if your token expires after a period of time. Then, configure the additional options that appear.
Refresh token (required) | Enter the refresh token. To specify the location, reference it in the appropriate section of the placeholder: {{{connection.http.auth.token.refreshToken}}} Note that there are multiple layers of protection in place (including AES 256 encryption) to keep your refresh token safe |
Refresh relative URI (optional) | Enter the relative URI for refreshing the token. |
Refresh media type (optional) | Select a data format. |
Refresh method (optional) | Select the HTTP method to use. |
Refresh token path (optional) |
If the service being connected to supports requests to obtain or refresh existing tokens, use this field to indicate to integrator.io what path to use against the HTTP response to extract the new token. If no value is found at this path then the token request is considered a failure. |
Refresh token headers (optional) |
Specify custom HTTP headers with your token refresh requests. |
Authentication fail status code (optional): Enter the status code if the service you are connecting to returns a status code other than 401 or returns 200 with authentication errors in the HTTP body.
Authentication fail path (optional): Specify the path if the service you are connecting to embeds authentication errors in the HTTP body. integrator.io uses these values to identify a failed authentication response.
Authentication fail values (optional): Enter the appropriate values if the authentication fail path is set. integrator.io uses these values to recognize a failed authentication response.
If needed, configure the settings in the additional sections:
- Nonstandard API rate limiter
- How to test connection?
- Advanced
- Save & close – click to test and save the connection and exit theCreate connectionpane
When you test or save the connection, it is verified before continuing. If the connection fails, double-check the provided settings and test again.
1 comment
The option to send the token in the body of the HTTP call is not well documented. How does one get the token entered into the body of the HTTP call? There's some help in the contextual help but it's not correct. I'm just had coding the token in the HTTP body for now.
