You use a different account type instead of a standard account object in Salesforce.
Note: You can modify the flow on the integrator.io new React UI.
Prerequisite: Be sure that the account that you are using is already in sync with the billing account and NetSuite customer respectively.
- Log in to integrator.io
- Click the Salesforce - NetSuite (IO) integration app
- Go to Flows and click on settings icon
- In the Additional data to export from Lookup fields setting, click edit and delete the prefixed word “Account” for all instances
- After you delete the prefixed word “account,” be sure that the billing account and the referenced field are still present
- Click Save
4 comments
Dear Gogula,
as of this article the "Listener: Setting: Referenced Fields" is editable, which is not the case for us. We already reinstalled the integration, but still same.
Do you have any hint on how to make it writeable, so we can adjust the values.
Thank you in advance.
Hello Christian,
There's a checkbox on the Integration App, "Sync account with opportunity" in Settings > Opportunity. To stop the account sync in the “Salesforce opportunity to NetSuite sales order” flow, you have to uncheck this setting. For more information, refer https://docs.celigo.com/hc/en-us/articles/360051280871-Salesforce-NetSuite-IO-release-notes-v1-7-0-October-2020 and https://docs.celigo.com/hc/en-us/articles/360052367672-Understand-Opportunity-related-Settings
Hi Laya,
Thank you for the input, found the setting from your linked articles.
May I conclude this article here is not outdated / not relevant anymore?
And I found a way to edit the referenced fields, related lists for the listener. For custom flows it would be as described above, but by using the integration app Salesforce / Netsuite, when you click on Listener these areas are greyed out and can not be edited. The article should be updated, here the way to get there: Within the integration app, click flows, select the object like "Account" and then on the setting gear for the flow you want to adjust. Within that dialogue you can then add additional reference field or sublists.
Best Christian
Hello Christian
I've updated the article to reflect the changes you mentioned and added another FAQ article for "Stop account sync in the Salesforce opportunity to NetSuite sales order flow".
Thanks
Laya
