Zoom documentation: API Guide, Authentication
A. Set up a Zoom connection
Start establishing a connection to Zoom in either of the following ways:
In the resulting Application list, select Zoom.
B. Supply required Zoom account information
At this point, you’re presented with a series of options for providing Zoom authentication.
API key (required): Enter the API key for your Zoom JWT bearer token app. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
API secret (required): Enter the API secret for your Zoom JWT bearer token app. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API secret safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
To look up your API key and secret, log in to your Zoom developer account at marketplace.zoom.us.
From the Develop menu, click Build app.
If you haven’t yet built a Zoom JWT bearer token app, click Create and describe your app.
In the App credentials section, copy your API key and API secret for your Zoom connection.
C. Edit advanced Zoom settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Zoom connection.
D. Test the connection
Once you have configured the Zoom connection, you have a few options for continuing:
