Skip to main content
Intro to Error Management
6 comments
  • viliandy leonardo Product Management Director
    We are rolling this new error management framework in phases. So, please leave a comment here if you are interested in migrating to the new error management sooner rather than later.
    As a reminder, if your account has Integration App (IA) or IA license or you plan to use IA, you'll need to wait till Feb 2021 to uptake the new features.
    Thanks
    1
  • Anna Orlova
    Hi,
    My flow doesn't give any errors, it just returns empty fields. How to troubleshoot that?
    -Anna
    0
    Answer Pro
    Top Contributor
    Anna Orlova
    I verified that your integrator.io account is not on the new error management. However, please raise a support ticket so they can discuss with you to better understand what fields are empty and then assist you with your questions.
    Thank you
    0
  • Nick Tabor
    I'd love to be able to jump right into a data flows' errors. With this new dashboard, its adds a click because it shows a breakdown of the steps. I guess "parent jobs" is no longer a concept. Top video [Using Dashboards], 29 second mark. Just something I'll have to get used to. Love the product!
    0
  • Anuj kumar Maurya
    Engaged
    Celigo University Level 4: Legendary
    Hey,
    I was working on Automatic resolve error by using trace key. So it worked fine.
    But when i need again to go back on previous stage like i don't want to resolve error so i turned it off from setting.
    Actually the problem arises when process is still resolving error and not showing latest errors in error log.
    So please check it, if there is any situation please response.
    0
    Answer Pro
    Top Contributor
    Anuj kumar Maurya
    I suggest that you log a case with support outlining steps to reproduce your scenario, what the problem is and what your expected result is. When the Auto-resolve errors is turned off, then integrator.io will not auto-resolve the errors.
    Thanks
    0
