MYOB Acumatica (previously MYOB Advanced) is a cloud-based ERP platform tailored to meet the needs of medium to large businesses, especially those looking to scale operations and gain more flexibility than standard accounting software typically offers.
Auth type * |
Select your MYOB Acumatica account authentication type (either Cookie or OAuth 2.0). |
Instance URI * |
Enter the instance URI shown in your Acumatica account URL. For example, if |
Endpoint name * |
Enter the endpoint name found in your MYOB Acumatica account. |
Endpoint version * |
Enter the endpoint version found in your MYOB Acumatica account. |
Username * (for Cookie auth type only) |
Enter the username for your MYOB Acumatica account. |
Password * (for Cookie auth type only) |
Enter the password for your MYOB Acumatica account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
Company |
Enter the company name for your MYOB Acumatica account. |
Locale |
Enter the locale for your MYOB Acumatica account. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by MYOB Acumatica. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Scopes * |
Scopes are OAuth 2.0 permissions that Slack defines to limit access to your account. |
Sign into your MYOB Acumatica account.
Navigate to Integration > Preferences > Connected applications.
Leave Client ID blank for a new app, or search for an existing app.
Provide a Client name.
Leave Active checked.
Choose Authorization code for the OAuth 2.0 flow.
In the Secrets tab, click Add shared secret.
Copy the Client secret.
