MYOB Advanced documentation: API Guide
Contents
- A. Set up an MYOB Advanced connection
- B. Supply required MYOB Advanced account information
- C. Edit advanced MYOB Advanced settings
- D. Test the connection
Start establishing a connection to MYOB Advanced in either of the following ways:
In the resulting Application list, select MYOB Advanced.
At this point, you’re presented with a series of options for providing MYOB Advanced authentication.
Authentication type (required): Select Cookie (the OAuth 2.0 option is described separately).
Instance URI (required): Enter the instance URI shown in your MYOB Advanced account. For example, if https://demo.myobadvanced.com/entity/Default/18.200.001
is the base URI, then the instance URI would be demo.myobadvanced.com
Endpoint name (required): Enter the endpoint name found in your MYOB Advanced account.
Endpoint version (required): Enter the endpoint version found in your MYOB Advanced account.
Username (required): Enter the username for your MYOB Advanced account.
Password (required): Enter the password for your MYOB Advanced account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
Company (optional): Enter the company name for your MYOB Advanced account.
Locale (optional): Enter the locale for your MYOB Advanced account.
Sign in to your MYOB Advanced account, navigate to the More items menu options and select Integration.
On the Integration page, you should see Web service endpoints in the Preferences section. If not, click Show more at the bottom of the page. Select Web service endpoints.
The page now displays the Endpoint name and Endpoint version, required for your connection:
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the MYOB Advanced connection.
Once you have configured the MYOB Advanced connection, you have a few options for continuing:
