Anaplan is a market-leading,cloud-native company transforming industries to see, plan, and drive business performance.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings.
Enter a clear and distinguishable name. (Throughout integrator.io imports and exports, you will have the option to choose this new connection.) A unique identifier will prove helpful later when selecting it from a list of the connections that you’ve created. |
Auth type * |
Select Token as the authentication type for this connection (the basic auth option is described separately). |
Username * |
Enter your Anaplan account username. |
Password * |
Enter your Anaplan account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
Use an FTP connector to upload files to Anaplan. If you are sending BLOB files from NetSuite to Anaplan, you can customize your flows based on the NetSuite to FTP template.
