Skip to main content
Attach and detach files
1 comment
  • Bhushan Rane Integration Engineer
    Hi Tom Santiago
    Generally users are adding files to the NS records like a SO. Should we add this to the above documentation that the Attached Record Type should put as "file" as this is not very evident other wise?
    Also, it's not clear what the Attribute Role and Attribute Field should be? From the flows I worked on, it seems these are not even required. Can we please clarify these two mappings as well?
    0
