eBay documentation: API guide, Authentication
A. Set up an eBay (XML) connection
Start establishing a connection to eBay (XML) in either of the following ways:
In the resulting Application list, select eBay (XML).
The Create connection pane opens with general and advanced settings.
B. Describe the eBay (XML) connection
C. Supply required eBay (XML) account information
The Application details section contains additional settings for eBay (XML) authentication.
Account Type: Select either the Production or Sandbox environment.
API site id (required): Enter the eBay API site ID.
D. Edit advanced eBay (XML) settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the eBay (XML) connection.
Save & authorize – click to save the connection and exit the Create connection pane.
Cancel – click to exit without saving any new changes.
Enter your email and password and click Sign in.
Click Agree to establish the connection.
