There’s no straightforward way to unlock this field as it is locked from the bundle. Hence it can only be unlocked from the bundle.
Note: The latest version of Celigo CashApp Manager (40598) bundle has this field unlocked.
Steps to update the Celigo CashApp Manager (40598) bundle:
- Search for the below files in your NetSuite account and download them as a backup. When you update the bundle, these script files are updated.
Note: If there are any changes made to these files after the bundle is installed for the first time, the changes are lost upon bundle installation.
- Celigo.build.Lockbox.v2.js
- Celigo.products.lockbox.userevent.BatchUserEventHandler.js
- Celigo.products.lockbox.usereventTransactionUserEventHandler.js
- Celigo.products.lockbox.userevent.CreditMemoUserEventHandler.js
- Celigo.products.lockbox.userevent.InvoiceUserEventHandler.js
- Update the bundle. Navigate to Customization > SuiteBundler > Search & Install Bundles > List. Search for the bundle with ID 40598. Under the settings, click on Update and confirm the install updates in the next page.
- Once the bundle is installed, replace the files with the downloaded files.
- Verify that the transaction body field is unlocked now. Go to Customization > Lists, Records, & Fields > Transaction Body fields and search for CashApp transaction field.
