Freshsales (formerly Freshworks CRM) is an intuitive CRM with built-in phone and email, tasks, appointments, and notes, that help sales reps do hassle-free prospects.
This video demonstrates creating a Freshsales connection.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings.
Setting | Instructions |
Name your connection* | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections that you’ve created. |
Subdomain* | Enter your Freshsales subdomain. For example, if your Freshsales account is located athttps://test96529.myfreshworks.com/crm/sales/,then test96529 is your subdomain. , then test96529 is the subdomain. |
API key* | Enter your Freshsales API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom universal connector documentation.
How to retrieve the API key
- Sign in to your Freshsales account.
- Click on your profile picture at the top right corner of your portal.
- Click the Pencil icon to navigate to Personal settings > API settings.
- Copy API key.
