Freshworks CRM documentation: API Guide, Authentication
A. Set up a Freshworks CRM connection
Start establishing a connection to Freshworks CRM in either of the following ways:
In the resulting Application list, select Freshworks CRM.
B. Supply required Freshworks CRM account information
At this point, you’re presented with a series of options for providing Freshworks CRM authentication.
Subdomain (required): Enter your Freshworks CRM subdomain, where you sign in to your account. For example, if https://test.myfreshworks.com/crm/marketer/mas/#/settings/domain-verify is the URL, then type test for this setting.
API key (required): Paste in the API key from your Freshworks CRM account. Multiple layers of protection are in place, including AES 256 encryption, to keep this value safe. When editing this form later, you must enter this value again; it is stored only for a saved connection.
- Sign in to your Freshworks CRM store.
- From your profile avatar at the top right, select Settings.
- Navigate to the API settings tab.
- Copy the API key.
C. Edit advanced Freshworks CRM settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Freshworks CRM connection.
D. Test the connection
Once you have configured the Freshworks CRM connection, you have a few options for continuing:
