Walmart Canada documentation: Marketplace API guide, Authentication
A. Set up a Walmart Canada connection
Start establishing a connection to Walmart Canada in either of the following ways:
In the resulting Application list, select Walmart Canada.
B. Supply required Walmart Canada account information
At this point, you’re presented with a series of options for providing Walmart Canada authentication.
Consumer ID (required): Paste the consumer ID generated at the Walmart Developer Portal.
Private key (required): Paste the private key for this consumer ID into this setting. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s key safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
Locale ID (required): Select a value for an English or French Canadian locale.
- Enter the Walmart Canada Developer portal, and click My Account at the top right.
- In the resulting account selection, choose the type Marketplace.
- Sign in with your email address and password.
- From the Settings menu, select Consumer IDs & private keys.
- Copy the consumer ID and private key. If none exists yet or you want to change the API credentials, click to generate a new pair.
C. Edit advanced Walmart Canada settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Walmart Canada connection.
E. Test the connection
Once you have configured the Walmart Canada connection, you have a few options for continuing:
