Set up a connection to Cart.com
Cart.com is a unified commerce and logistics platform that empowers B2C and B2B brands to manage their entire commerce operations, from product discovery to order delivery.
Setting
Instructions
Name your connection *
Subdomain *
Enter your Cart.com account subdomain. For example, if your Cart.com account URL is https://celigo.cart.com/, then celigo.cart.com is the subdomain.
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Cart.com.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Valid domain names *
Enter your Cart.com valid domain name. For example, if your Cart.com account URL is https://celigo.cart.com/, then celigo.cart.com is the valid domain name.
Callback URL *
Enter the Celigo integrator.io Callback URL.
Scopes *
Scopes are OAuth 2.0 permissions that Cart.com defines to limit access to your account.
How to configure scopes
  1. Sign in to your Cart.com admin account.
  2. Navigate to Tools > Apps and addons > API Apps and integrations.
  3. Click New.
  4. Select Scopes.
  5. Click Save.
  6. Copy the App ID (Client ID).
  7. Copy the App secret (Client secret).
  1. Click Scope.
    – or –
    Check the scopes you want to add and click the>button.
  3. Click Save.
Additional references
