Set up a custom HTTP connection to Walmart DSV
Walmart supplier help: DSV API guide , Authentication
A. Set up an HTTP connection
Start establishing an HTTP connection to Walmart DSV in either of the following ways:
    – or –
B. Edit HTTP application details
This article is concerned only with the settings needed for Walmart DSV connections. For complete field documentation, see Set up a custom HTTP connection.
Configure HTTP headers: Add the following headers, with the values provided with your Walmart account:
Name
Value
WM_CONSUMER.CHANNEL.TYPE
Enter the Consumer Channel Type received during onboarding
WM_SVC.NAME
Enter Walmart Gateway API
WM_CONSUMER.ID
Copy the Consumer ID you see when signed into the Developer Center
Base URI: Enter https://api-gateway.walmart.com/v3.
Media type: Select XML.
C. Configure auth settings
Continuing in the Create connection pane, select Custom for the Authentication type. The settings then become specific to custom HTTP connections:
Encrypted: Provide your value for the {'consumerKey': '<consumer key/private key>'}.
D. Specify how to test the connection
Scroll down farther to the How to test this connection? section:
Ping relative URI: Enter /items.
Ping method: Select GET.
E. Test the connection
Once you have configured the Walmart DSV connection, you have a few options for continuing:
