All article conventions follow Celigo technical style for consistency and clarity.
Convention | Description | Example |
Articles in this section | A menu that displays all the articles included in the selected section of the knowledge base. They appear to the left of the article on most screen resolutions. | ![]() |
Avatar | Your avatar displays your image and, when selected, shows all your associated tickets, comments, and community posts. | ![]() |
Bold | “Bolded” words create emphasis and reference the name of a button or resource in integrator.io. | Click + Create integration or Settings |
Breadcrumbs | Breadcrumbs display your current location in the Help Center and display the hierarchy of documents in the section. | ![]() |
Created/updated date and author | The name, image, and update day for the document. |
Kathyana Rule updated this article one month ago. |
Icons | Icons are used sparingly to display a specific button a user should click. For example, the settings icon. | |
Jump links | Links that open other articles or web pages in a new tab or window are designated by a jump link icon. | Celigo |
Naming Conventions |
Trademarks are styled per the application’s branding guidelines | NetSuite, BigCommerce, eBay |
File types are always capitalized | PDF, CSV, EDI | |
Proper nouns are always capitalized. |
Welcome to Celigo. Select the connector, connection, or Integration App you would like to use. |
Sample data | Sample data is written in an inline monospace variant with a gray highlight to distinguish it from the rest of the article. |
My Object |
Titles | Article titles are always in sentence case – meaning only the first word is capitalized | Article title: Map source record fields to destination |
Underlines | Underlines designate a link on hover. | Celigo |
