Set up a token-based connection to PagerDuty
PagerDuty is an incident management platform that provides reliable notifications, automatic escalations, on-call scheduling, and other functionality to help teams detect and fix infrastructure problems quickly.
This video demonstrates creating a PagerDuty connection.
Setting
Instructions
Name your connection *
Auth type *
Select Token as the authentication type for this connection (the OAuth 2.0 option is described separately).
API key*
Enter your PagerDuty API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Fetch data {//theme.zdassets.com/theme_assets/1098969/5157503509223f89f9b3e7578d2ca78ce882fc18.svg}How to retrieve the API key
How to retrieve API key
  1. Sign in to your PagerDuty developer account.
  2. Navigate to Integrations > Developer tools > API access keys.
  3. Click + Create new API key. The Create API key page opens.
  4. Enter a Description.
  5. Check Read-only API key according to your requirements.
  6. Click Create key. The New API key details page opens.
  7. Copy API key.
If you do not copy your new API key, you cannot see it again.
