PagerDuty Events documentation: API guide, Authentication, Supported endpoints
PagerDuty is an incident management platform that provides reliable notifications, automatic escalations, on-call scheduling, and other functionality to help teams detect and fix infrastructure problems quickly.
A. Set up a PagerDuty Events connection
Start establishing an OAuth 2.0 connection to PagerDuty Events in either of the following ways:
In the resulting Application list, select PagerDuty Events.
B. Edit PagerDuty Events application details
At this point, you’re presented with a series of options for providing PagerDuty Events authentication.
Application details
Routing key (required): Enter your PagerDuty Events routing key. Use the following steps to retrieve your routing key from PagerDuty.
- Log in to your PagerDuty account.
- From the dashboard, click Integrations, and in the Developer Tools section, click Developer Mode.
- Select the app (or create one), and in the Functionality section, click Manage in the Events Integration section.
- Copy the integration key from the Events API Endpoint URL.
The endpoint URL has the following formatting:
https://events.pagerduty.com/integration/<Integration Key>/enqueue
- Copy the
<Integration Key>
value to use as the routing key.
Redirect URL (read-only): Copy this integrator.io callback URL when creating your PagerDuty Events app for where to go after authentication. (This URL should be whitelisted with the authorization server.)
https://integrator.io/connection/oauth2callback
C. Edit advanced PagerDuty Events settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the PagerDuty Events connection.
D. Test the connection
Once you have configured the PagerDuty Events connection, you have a few options for continuing:
- Close – click to exit without saving any new changes
