Contents
"Employee Onboarding and Offboarding for ADP" business process automation focuses on the employee lifecycle in a company. This begins with workforce planning and continues on to hiring and onboarding, workforce management such as employee data, time recording, and payroll, and ends with employee off-boarding. This template allows you to streamline the Human Resource business processes by allowing you to provision and deprovision users from ADP Workforce Now into one or more applications where ADP Workforce Now acts as a hub and the source of truth for an employee record.
Features and benefits
- Set of prebuilt unmanaged workflows for quick start and easy customization between different applications and ADP Workforce Now.
- Ability to pick and choose destination applications during and after installation of the template.
- Save time and minimize errors by eliminating manual data entry.
- Provisioning and Deprovisioning flows are batch flows.
Supported integration flows
The Celigo quickstart bundle contains workflows that you can easily configure and deploy without coding or IT support. The following built-in flows sync from the specified source data to the corresponding destination.
Flow | What’s not supported |
Provisioning: Provision user access from ADP |
Updating user details in destination applications. Note: Support for updates can be achieved by changing import configuration. |
Deprovisioning: Deprovision user access from ADP |
Removing the user from all the applications but one, GitHub. |
Error handling
Most integrator.io error messages will clearly explain the error and suggest troubleshooting methods. If you are unsure of what the error means, contact Celigo support.
