Contents
What’s new
Support for Base64-encoded, Gzip-compressed strings
This functionality has been requested by customers to solve real-world integration challenges. For example, eCommerce businesses can now extract shipping labels from Amazon Seller Central and bring better visibility to their Warehouse & Customer Support teams via other systems, such as an FTP server or NetSuite File Cabinet.
New connectors
Built-in connectors are now available for Mixpanel and SAP S/4HANA Cloud.
What’s enhanced
Revised connectors
Salesforce API version 52.0 is now supported – you can export and import newly introduced sObjects, such as Return Orders.
In addition, the Freshservice, Mavenlink, Miva, SAP Business ByDesign, SAP SuccessFactors, Shopify, and Square connectors have been updated according to the vendors’ latest APIs.
Additional extended characters allowed in requests
Universal HTTP connections now include support for ISO-8859-1 character set encoding in exported data.
What’s fixed
- When all records were filtered prior to a Snowflake lookup step, the connection would return an “uncaught exception” error
- Syncing gift certificates from NetSuite to Salesforce Commerce Cloud would update the wrong item, due to a nlapiSubmitField function limitation for inbound shipment on custom fields*
- In NetSuite custom forms with radio buttons, discount types were not populating flat and percentage values correctly*
- Fixed-width files imported (uploaded) to Amazon S3 and FTP servers had “.edi” file extensions, regardless of the type chosen
- Updates to Salesforce attachments generated the error “Unable to create/update fields: ParentId,” even though that field was not mapped
- FTP exports set to a large batch size with an exceptionally large number of records produced the cryptic error “Cannot set property 'resolved' of undefined”
- AS2 connections to HID Global partners would work as HTTP but not HTTPS
- Cookies in redirected HTTP connections were not being passed through to the API, yielding an “exceeded maxRedirects” error
- The handlebars helper {{hmac}} was not producing valid results in refresh token headers
- The values in JSON number arrays were not formatted correctly
- NetSuite Contacts and Contact Roles customer sublists were not available for exports or import field mapping*
- In the Advanced field editor (AFE), if you started typing a field name, such as
record.E
for Email, and pressed Enter after typingrecord.
, autocomplete would begin the full path with your initial value, such asrecordrecord.Email
, instead of the selectedrecord.Email
as intended - Field names containing a space would show up in the AFE autocomplete list only after typing
, instead of the expected initial letters
__________________
* This feature relies on the integrator.io bundle for NetSuite v1.19.1.0, which was released on October 19, 2021 and will be applied to customers’ Production accounts in phases throughout the following few weeks. The release is immediately available for Sandbox accounts, and you must manually upgrade the bundle in your NetSuite Sandbox Environment. (In compliance with NetSuite policies, Celigo cannot automatically update bundles in Sandbox accounts, only in Production accounts.)
