Propack™ is a third-party logistics (3PL) company in Blaine, WA that is specialized in fulfillment, freight forwarding, and package cross dock services.
Propack documentation: API guide
Contents
- A. Set up a Propack connection
- B. Describe the Propack connection
- C. Provide required Propack account information
- D. Edit advanced Propack settings
- E. Test the connection
Start establishing a connection to Propack in either of the following ways:
In the resulting Application list, select Propack.
At this point, you’re presented with a series of options for providing Propack authentication.
Environment (required): Select one of the following, depending on the account type you are connecting to:
- Production: your live production environment
- Test: a sandbox environment for user-acceptance testing
P3PL user ID (required): Enter your registered Propack P3PL account user ID.
P3PL user password (required): Enter your registered Propack P3PL account user password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Propack connection.
Borrow concurrency from (optional): Select another connection from the list. By default, all data flowing through a connection record is submitted to the respective endpoint application at the Concurrency level configured for that connection record. There are cases, however, where multiple integrator.io connections need to share the same concurrency level, and this field allows you to specify which connection you would like to borrow from. With borrowed concurrency, the data flowing through both connections will be submitted to the endpoint application together, via a shared concurrency model.
Concurrency level (optional): Up to 25 allowed...
Once you have configured the Propack connection, you have a few options for continuing:
- Save – click to test the connection, commit the new connection so that it will be available to all integrations for your account
- Close – click to exit without saving any new changes
- Test connection – click to verify that your new connection is free of errors
