When you configure an export, import, or other type of flow step using the form view designed for the SAP Concur Expense and SAP Concur Invoice connectors, the API operations listed in the tables below are supported.
Supported Concur Expense APIs
API | Operation | Export | Import |
Common : Lists v3 (Deprecated) | Gets all lists (Deprecated) | X | |
Gets a single list by ID (Deprecated) | X | ||
Create a new list (Deprecated) | X | ||
Common : Extracts | GET a list of extract definitions | X | |
Get extract definition details | X | ||
Get an extract job list | X | ||
Get Extract Job Details | X | ||
Get Extract Job Status | X | ||
Get an extract file or files | X | ||
POST an extract job initiation request | X | ||
Common : List Items v3 (Deprecated) | Retrieve all list items based on the search criteria (Deprecated) | X | |
Retrieve a list item by ID (Deprecated) | X | ||
Create a new list item (Deprecated) | X | ||
Update a list item (Deprecated) | X | ||
Create or Update List Item (Deprecated) | X | ||
Delete a list item (Deprecated) | X | ||
Common : Locations | Retrieve details of locations that are used by Concur | X | |
Retrieve details of a specified location | X | ||
Expense : Allocations | Retrieve all allocations per entry or report | X | |
Retrieve a single allocation by ID | X | ||
Expense : Attendee Types | Retrieve all attendees types | X | |
Retrieve attendee types by ID | X | ||
Update existing attendee type | X | ||
Expense : Attendees | Retrieve all attendees owned by the specified user | X | |
Retrieve a single attendee by ID | X | ||
Create a new attendee | X | ||
Update existing attendees | X | ||
Create or Update attendee | X | ||
Expense : Digital Tax Invoices | Retrieve all digital tax invoices that can be validated by the user based on the search criteria | X | |
Retrieve a single digital tax invoice by ID | X | ||
Update a specified digital tax invoice | X | ||
Expense : Company Card Transaction | Get company card transactions | X | |
Expense : Expense delegators | Get expense delegators | X | |
Expense : Entry Attendee Association | Retrieve all digital tax invoices that can be validated by the user based on the search criteria | X | |
Retrieve an entry-attendee association by ID | X | ||
Create a new entry-attendee association | X | ||
Update a specified entry-attendee association | X | ||
Create or Update entry-attendee association | X | ||
Deletes the specified entry-attendee association. | X | ||
Expense : Entries | Get List of Reports Request | X | |
Create a new expense entry | X | ||
Updates an expense entry | X | ||
Create or Update Entry | X | ||
Delete an expense entry | X | ||
Expense : Expense Form Field | Get a list of form fields | X | |
Expense : Expense Form | Get Form Types | X | |
Get Form Data | X | ||
Expense : Expense Group Configurations | Retrieve a configuration of an expense group | X | |
Retrieve an expense group configuration by ID | X | ||
Expense : Itemizations | Get all expense itemizations | X | |
Retrieve an expense itemization by ID | X | ||
Create a new expense itemization | X | ||
Expense : Reports | Retrieve reports owned by the user based on search criteria | X | |
Retrieve a report by ID | X | ||
Create a new report | X | ||
Update a report | X | ||
Create or Update Report | X | ||
Expense : Payment Batches | Retrieve the list of payment batches | X | |
Close a payment batch | X | ||
Expense : Integration Status | Post an integration status for a report | X | |
User | Retrieve a user’s information | X | |
Gets all users based on the search criteria. | X | ||
Retrieve the list of required fields for creating a user | X | ||
Get User | X | ||
Update a User’s Account Information | X | ||
Update a User’s Password | X | ||
Company | Get Company | X | |
Receipt Image: Image | Get an image URL | X | |
Common : Lists v4 | Get All Lists | X | |
Get a List by List ID | X | ||
Get a List by Category ID | X | ||
Create a new list | X | ||
Update a list | X | ||
Create or Update List | X | ||
Common : List Items v4 | Retrieve First Level Children Items of a List | X | |
Retrieve a List Item by ID | X | ||
Retrieve Children of a List Item | X | ||
Retrieve Children of a List Item by List | X | ||
Create a List Item | X | ||
Update a List Item | X | ||
Create or Update List Item | X | ||
Delete a list item | X | ||
Delete a List Item from a List | X |
Supported Concur Invoice APIs
Get User | X | ||
Invoice : Vendor | Retrieve an existing vendor | X | |
Create vendors | X | ||
Update existing vendors | X | ||
Create or Update Vendor | X | ||
Delete vendor | X | ||
Invoice : Retrieve Payment Requests Digest | Retrieves all payment requests digests based on the search criteria | X | |
Retrieves a payment request digest based on ID | X | ||
Invoice : Invoice | Retrieve an Invoice | X | |
Create a New Invoice | X | ||
Update an Invoice | X | ||
Create or Update an Invoice | X | ||
Invoice : Purchase Order Receipt | Get an Existing Purchase Order Receipt | X | |
Create a new purchase order receipt | X | ||
Update purchase order line item with receipt information | X | ||
Delete a List Item from a List | X | ||
Invoice : Purchase Orders | Get an Existing Purchase Order | X | |
Update Purchase Order Line Item With Receipt Information | X |
