ServiceNow is a cloud computing platform that helps companies to manage digital workflows for enterprise operations.
Subdomain * |
Enter your ServiceNow subdomain. For example, if your ServiceNow account URL is |
Username * |
Enter your ServiceNow account username. |
Password * |
Enter your ServiceNow account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text. |
Auth type * |
Select OAuth 2.0 as the authentication type. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided by ServiceNow. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Sign in to your ServiceNow instance.
Navigate to System definition > Plugins. The All applications page appears.
Search for OAuth 2.0 and click Install.
In the Activate Plugin dialog box, select Activate for (com.snc.platform.security.oauth).
By default, this plugin is active for upgraded and new instances.
Navigate to System OAuth > Application registry and click New.
Click Create an OAuth API endpoint for external clients. The Application registries new record page appears.
Provide a Name and click Submit. The new registry gets added.
Click the registry and copy the Client ID and Clientsecret.
If you already created an application registry, you can select the registry and copy the Client ID and Client secret.
