You can undo changes and revert to an earlier revision in case of an error, software issue, or business requirement. You can revert to a revision based on a snapshot, pull, or revert at any time. For more information, see Revisioning an integration.
Contents
Revert to a snapshot
You can revert to a snapshot that you’ve created if you’ve run into an issue.
- On the Home page, click an integration to open it.
- On the integration page, click the Revisions tab.
- In the Revions list, select the snapshot revision and click the Actions overflow (...) menu.
- In the dropdown list, select Revert to this revision.
- Enter a description for the revert revision and click Next.
- Review changes and click Next.
- In the Revert changes pane, click Revert. When the revert is successfully completed, this revision is added to the revision list.
Revert to a pull or revert
- In the Revisions list, select either a pull or revert revision and click the Actions overflow (...) menu.
- In the drop-down list, choose one of the following options:
- Revert to before this revision: Select this option to revert to an integration state before the pull or revert was made.
- Revert to after this revision: Select this option to revert to an integration state after a pull or revert was made.
- Review changes and click Next to continue. Note that reverting your changes will never create conflicts.
- In the Revert changes pane, click Revert.When the revert is successfully completed, the revision is added to the revision list.
View details of a revert
You can view details of any revert that is listed in the revision history.
- In the Revisions list, select the revision and click the Actions overflow (...) menu.
- In the drop-down list, select View details.
- Review the details and click Close.
View resources changed in a revert
You can view the resources that have changed in a revert.
- In the Revisions list, select the revert revision and click the Actions overflow (...) menu.
- In the drop-down list, select View resources changed.
- Expand each section to review the modified resources and click Close.
