Download Postman collection
Create a connection in integrator.io
Get a specific connection.
Method |
Relative URI |
Response body structure |
{ "_id": "554••••••••••••••••••00d", "lastModified": "2015-05-02T05:13:43.736Z", "type": "rest", "name": "Slack API", "rest": { "baseURI": "https://slack.com/api", "bearerToken": "•••••••", "tokenLocation": "url", "tokenParam": "token", "mediaType": "urlencoded", "authType": "token", "encryptedFields": [], "unencryptedFields": [], "scope": [], "pingRelativeURI": "api.test" }, "queues": [ { "name": "554••••••••••••••••••00d", "size": 8 } ] } |
Update a specific connection.
connections.update( connection )
Method |
Relative URI |
Update part of a specific connection.
The following fields are available for update using PATCH
. You must use the provided format to update the field.
Fields |
Subfields |
Data type |
Method |
Relative URI |
Request body structure |
[ { "op": "replace", "path": "/fieldname", "value": "newvalue" } ] |
{ "_id":"554••••••••••••••••••00d", "lastModified":"2015-05-02T05:13:43.736Z", "type":"rest", "name":"Slack API", "rest": { "baseURI":"https://slack.com/api", "bearerToken":"•••••••", "tokenLocation":"url", "tokenParam":"token", "mediaType":"urlencoded", "authType":"token", "encryptedFields":[ ], "unencryptedFields":[ ], "scope":[ ], "pingRelativeURI":"api.test" }, "queues":[ { "name":"554••••••••••••••••••00d", "size":8 } ] } |
Delete a specific connection.
Method |
Relative URI |
Test a virtual connection where all connection details are submitted in the POST
body but not saved.
Method |
Relative URI |
{ "code": 200 } |
Execute a virtual export using a connection identified by _id
by posting the export model to this endpoint.
Method |
Relative URI |
{ "export": { "name": "sfdummyconnection", "_connectionId": "641•••••••••••••••••913", "asynchronous": true, "oneToMany": false, "sandbox": false, "rawData": "640•••••••••••••••••••4a8", "salesforce": { "type": "soql", "api": "rest", "soql": { "query": "Select Name,Email__c,phone,fax from Account where name like 'test7676'" } }, "adaptorType": "SalesforceExport" } } |
Alternative virtual export execution with paging support.
Method |
Relative URI |
Export data from an external application using a virtual export, with paging (size 5) { "export": { "asynchronous": true, "pageSize": 5, "netsuite": { "type": "search", "searches": [ { "recordType": "customRecord", "savedSearchId": "131298" } ], "skipGrouping": true } } } Retrieve additional pages This example builds on the previous one to demonstrate how to get the next page of data for the same virtual export. It includes the exact pagedExportState object that was returned by the first API response. To get the next page after this, you can submit the pagedExportState returned by this API response. { "pagedExportState": { "searchId": "WEBSERVICES_589861_11292017182391545425518660_73666d20757aff", "pageIndex": 2, "pageSize": 5, "totalPages": 165, "totalRecords": 822, "done": false, "issuedAt": 1512010880, "sig": "ac7463cf6160937468e5cc575f541d438763719f5985c0ee85642e0de4d75d0d" }, "export": { "asynchronous": true, "pageSize": 5, "netsuite": { "type": "search", "searches": [ { "recordType": "customRecord", "savedSearchId": "131298" } ], "skipGrouping": true } } } Import four records into an external app using a virtual import The import object in the request defines how integrator.io should import the data, and the data array contains all the records that you want to import. { "import": { "mapping": { "fields": [ { "extract": "timestamp", "generate": "timestamp" }, { "generate": "key", "hardCodedValue": "sqs_flow" } ] }, "rest": { "relativeURI": [ "/system/v1/heartbeat" ], "method": [ "PUT" ] } }, "data": [ { "timestamp": 1512012818751 }, { "timestamp": 1512012818751 }, { "timestamp": 1512012818751 }, { "timestamp": 1512012818751 } ] } |
Export data from an external application using a virtual export, with paging (size 5) { "data":[ { "recType":"813", "Trial Start":"2017-09-15T14:02:00.000-07:00", "custrecord_license2_trial_end_date":"2017-10-19T07:00:00.000+00:00", "custrecord_usage_diy_phone":"555-555-5555", "custrecord_usage_diy_ms":65894782, "custrecord_usage_diy_year":2017, "custrecord_usage_diy_company":"Acme Products", "custrecord_usage_diy_userid":"63fv1h4c7390c457ak1d20v2", "custrecord_usage_diy_name":"John Doe", "custrecord_usage_diy_hours":18, "custrecord_usage_diy_role":"Consultant", "custrecord_usage_diy_email":"jdoe@example.com", "custrecord_usage_diy_month_s":"November" }, { "recType":"813", "Trial Start":"2016-11-22T12:26:00.000-08:00", "custrecord_license2_trial_end_date":"2017-06-22T07:00:00.000+00:00", "custrecord_usage_diy_phone":"7777777777", "custrecord_usage_diy_ms":44439899, "custrecord_usage_diy_year":2017, "custrecord_usage_diy_company":"Widgets Inc.", "custrecord_usage_diy_userid":"999••••••••••••••910", "custrecord_usage_diy_name":"Jane Doe", "custrecord_usage_diy_hours":12, "custrecord_usage_diy_role":"Technology", "custrecord_usage_diy_email":"JDoe2@example.com", "custrecord_usage_diy_month_s":"November" }, { "recType":"813", "Trial Start":"2017-11-13T01:31:00.000-08:00", "custrecord_license2_trial_end_date":"2017-12-13T08:00:00.000+00:00", "custrecord_usage_diy_phone":"+5555555555", "custrecord_usage_diy_ms":33199382, "custrecord_usage_diy_year":2017, "custrecord_usage_diy_company":"Example Services", "custrecord_usage_diy_userid":"999••••••••••••••91x", "custrecord_usage_diy_name":"Joe Smith", "custrecord_usage_diy_hours":9, "custrecord_usage_diy_role":"Manager", "custrecord_usage_diy_email":"Joe.Smith@example.com", "custrecord_usage_diy_month_s":"November" }, }, "dataURIs":{ null, null, null, null, null ], "pagedExportState": { "searchId":"WEBSERVICES_589861_11292017182391545425518660_73666d20757aff", "pageIndex":2, "pageSize":5, "totalPages":165, "totalRecords":822, "done":false, "issuedAt":1512010880, "sig":"ac7463cf6160937468e5cc575f541d438763719f5985c0ee85642e0de4d75d0d" } } Retrieve additional pages This example builds on the previous one to demonstrate how to get the next page of data for the same virtual export. It includes the exact pagedExportState object that was returned by the first API response. To get the next page after this, you can submit the pagedExportState returned by this API response. { "data":[ { "recType":"813", "Trial Start":"2017-06-14T09:02:00.000-07:00", "custrecord_license2_trial_end_date":"2017-09-30T07:00:00.000+00:00", "custrecord_usage_diy_year":2017, "custrecord_usage_diy_hours":4, "custrecord_usage_diy_month_s":"November" }, { "recType":"813", "Trial Start":"2016-03-09T08:18:00.000-08:00", "custrecord_license2_trial_end_date":"2017-09-02T07:00:00.000+00:00", "custrecord_usage_diy_year":2017, "custrecord_usage_diy_hours":2, "custrecord_usage_diy_month_s":"November" }, { "recType":"813", "Trial Start":"2016-11-17T12:25:00.000-08:00", "custrecord_license2_trial_end_date":"2017-12-04T08:00:00.000+00:00", "custrecord_usage_diy_year":2017, "custrecord_usage_diy_hours":2, "custrecord_usage_diy_month_s":"November" }, { "recType":"813", "Trial Start":"2017-10-31T11:30:00.000-07:00", "custrecord_license2_trial_end_date":"2017-12-02T08:00:00.000+00:00", "custrecord_usage_diy_year":2017, "custrecord_usage_diy_hours":1, "custrecord_usage_diy_month_s":"November" }, { "recType":"813", "Trial Start":"2017-09-16T16:02:00.000-07:00", "custrecord_license2_trial_end_date":"2017-12-25T08:00:00.000+00:00", "custrecord_usage_diy_year":2017, "custrecord_usage_diy_hours":1, "custrecord_usage_diy_month_s":"November" } ], "dataURIs":[ null, null, null, null, null ], "pagedExportState":{ "searchId":"WEBSERVICES_589861_11292017182391545425518660_73666d20757aff", "pageIndex":3, "pageSize":5, "totalPages":165, "totalRecords":822, "done":false, "issuedAt":1512010952, "sig":"de523935aa3831a8d4ab49e788b22ba5c1be021a60db597b7c5a0033a669af9f" } } Import four records into an external app using a virtual import The import object in the request defines how integrator.io should import the data, and the data array contains all the records that you want to import. [ { "statusCode":200, "id":"5a1••••••••••••••••••ab6", "_json":{ "_id":"5a1••••••••••••••••••ab6", "lastModified":"2017-11-30T03:33:51.703Z", "createdAt":"2017-11-21T21:37:10.497Z", "key":"sqs_flow", "timestamp":"2017-11-30T03:33:38.751Z", "__v":0 } }, { "statusCode":200, "id":"5a1••••••••••••••••••ab6", "_json":{ "_id":"5a1••••••••••••••••••ab6", "lastModified":"2017-11-30T03:33:51.704Z", "createdAt":"2017-11-21T21:37:10.497Z", "key":"sqs_flow", "timestamp":"2017-11-30T03:33:38.751Z", "__v":0 } }, { "statusCode":200, "id":"5a1••••••••••••••••••ab6", "_json":{ "_id":"5a1••••••••••••••••••ab6", "lastModified":"2017-11-30T03:33:51.700Z", "createdAt":"2017-11-21T21:37:10.497Z", "key":"sqs_flow", "timestamp":"2017-11-30T03:33:38.751Z", "__v":0 } }, { "statusCode":200, "id":"5a1••••••••••••••••••ab6", "_json":{ "_id":"5a1••••••••••••••••••ab6", "lastModified":"2017-11-30T03:33:51.701Z", "createdAt":"2017-11-21T21:37:10.497Z", "key":"sqs_flow", "timestamp":"2017-11-30T03:33:38.751Z", "__v":0 } } ] |
Execute a virtual import using a connection identified by _id
by posting the import model to this endpoint.
Method |
Relative URI |
Evaluate only the mapping step in a virtual import and return the set of post-mapped records.
Method |
Relative URI |
Get a log for a specific connection.
Method |
Relative URI |
[ { "_id": "554•••••00d", "resourceType": "connection", "_resourceId": "67e••••••••••3cb", "source": "ui", "fieldChanges": [], "event": "create", "time": "2025-03-28T15:22:51.518Z", "byUser": { "_id": "60c••••••••••6f6", "email": "email@email.com", "name": "Your Name" } } ] |
Create an OAuth 2.0 connection in Celigo via a third-party portal.
Method |
Relative URI |
Get all resources using or used by this connection.
Method |
Relative URI |
{ "exports": [ { "id": "65c•••••••••••440", "name": "NASA API Export", "paths": [ "_connectionId" ], "accessLevel": "manage", "dependencyIds": { "connection": [ "65c•••••••••••c8c" ] } } ], "flows": [ { "id": "65c••••••••••••••25c", "name": "NASA APOD - Slack", "paths": [ "pageGenerators[*]._exportId" ], "accessLevel": "manage", "dependencyIds": { "export": [ "65c•••••••••••••440" ] } } ], "integrations": [ { "id": "65c•••••••••••••••••c06", "name": "NASA Astronomy Picture of the Day to Slack", "paths": [ "_registeredConnectionIds[*]" ], "accessLevel": "manage", "dependencyIds": { "connection": [ "65c••••••••••••••c8c" ], "flow": [ "65c••••••••••••••25c" ] } } ] } |
