Celigo acquired the IP range 44.204.21.0/24 from Amazon Web Services, and has completed migration to this range for the North American instance of integrator.io as of August 19, 2022. In the past, you were required to allow (whitelist) individual IP addresses that can now be removed.
Note: This article applies to the North American instance of integrator.io only. If you are using eu.integrator.io, you must continue to allow the specific IP addresses listed here.
NA instance: integrator.io
integrator.io iPaaS (platform): Individual IP addresses no longer required in allowlists
23.22.248.166 52.1.127.16 52.4.194.5 52.6.244.241 52.7.170.62 52.20.54.118 52.70.11.159 52.72.83.124 52.73.94.116 52.87.95.248 52.87.147.142 52.201.165.30 52.202.86.239 52.204.140.17 |
52.204.150.194 52.204.205.3 52.204.245.141 52.205.7.8 52.205.21.215 52.205.31.59 52.205.126.104 52.205.183.233 52.205.185.233 52.205.185.70 52.205.185.117 52.205.186.153 52.205.189.244 |
52.205.191.11 52.205.192.79 52.205.208.140 52.205.209.108 52.205.213.1 52.205.213.243 52.205.215.50 52.205.215.161 52.205.215.221 52.205.216.9 52.205.216.59 52.205.216.69 54.87.174.71 |
integrator.io (FTP, SFTP, or FTPS): Individual IP addresses no longer required in allowlists
52.2.63.213 52.7.99.234 52.71.48.248 |
Agent-extension servers (on-premise agent – outbound): Individual IP addresses no longer required in allowlists
3.224.225.111 3.225.142.213 3.229.157.1 3.229.207.242 18.215.105.45 |
52.6.8.108 52.6.192.157 54.159.4.127 54.205.40.4 54.225.104.30 |
